I wish there were a notation for a2 which would play the notes on both voice 1 and 2 without actually copying out the notes to each voice!
Michael
with small AOC monitor for additional display macOS Ventura 13.4 2 - 500 gb + 2 - 1 tb external SSD for sample libraries M Audio AirHub audio interface Nektar Panorama P1 control surface Nektar Impact 49-key MIDI keyboard Focal CMS40 near-field monitors JBL LSR310S subwoofer Notion 6 + Studio One 5 Pro http://www.tensivity.com |
michaelmyers1 wroteI wish there were a notation for a2 which would play the notes on both voice 1 and 2 without actually copying out the notes to each voice! a2 actually does exist in the Notion 5 custom rules library/specification. I have not tried to use it in custom rules "yet". You can use "Express Entry" to get _a2, a3, solo & tutti_ onto your cursor which then you apply to your score. There is a lot of undocumented code for features that Notion 5 can use. At this point custom rules could trigger a key-switch or other control to add a 2nd sound to the mix switch samples etc. etc. I definitely think it is worth trying to figure out a way to use this feature. ,Newberry |
johnnewberry wroteYou can use "Express Entry" to get _a2, a3, solo & tutti_ onto your cursor which then you apply to your score. John, interesting. If they have built it into the custom rules library maybe there will be some future implementation. A2 seems to be a fairly standard musical notation: when this mark occurs, both instruments play the same notes following. Seems like it would be fairly straightforward to implement this.
Michael,
I think there's ways to use it now! Depending on what sound library is used different methods are possible. _In the example below a2 changes the MIDI channel which would have a sample of unison playing instruments. Another way may be to control or un-mute the volume of an internal or external audio mixer track that contained instrument #2 with MIDI control change. I would say there are at least a few other methods possible. ,Newberry |
