diminuendo to zero
Posted: Sun Sep 21, 2014 8:18 am
by rubenstubenchlak
Screen Shot 2014-09-21 at 11.14.37.png (3.17 KiB) Viewed 2413 times
Re: diminuendo to zero
Posted: Fri Sep 26, 2014 1:40 am
by fabiobiolcati1
Posted: Fri Sep 26, 2014 6:48 am
by thorrild
This is perfectly possible, and it also plays back:
1. Enter your notes in layer 1.
2. Switch to layer 2 and enter some rests so that you have a short rest at the end of the bar.
3. Enter the dynamic and the hairpin, ending the hairpin on the last rest.
4. Press K and click below the last rest. Type "o" in the text box.
5. In Notion 5, drag the "o" horizontally and vertically to where you want it.
6. Select all the rests in layer 2 and hide them (right-click, Attachments>Hide)
Screenshots of the bar with layer 2 hidden, and with Show Hidden Items.
Best,
Thorrild
Posted: Sat Sep 27, 2014 4:44 am
by rubenstubenchlak
yes Thorrild, also my attached image was made in Notion. But, as you can see in yours, it is not perfectly done, there is a gap... Besides the gap, as you go changing and changing again the composition the ยบ go out of place several times so you have to make thousands corrections. It becomes even worse when it is close to a barline...
But you are right, there can be much of the time some other work around to do manny things which take sometimes lots of time... Anyway the suggestions made here are meant to make a better software so we could have more time thinking in music then fixing visual or other lacks, and I also imagine that will be no pain for Notion team to make this sign as Sibelius had since... always!
Posted: Sat Sep 27, 2014 4:04 pm
by thorrild
rubenstubenchlak wrote[...] Anyway the suggestions made here are meant to make a better software [...]!
Forgive me if I missed your point: simply posting a picture of something that can be done, without a single word of explanation, is not, to me, a feature request.
With the best intentions,
Thorrild
Posted: Sun Sep 28, 2014 6:05 am
by rubenstubenchlak
Well... In the FEATURE REQUEST there's a title DIMINUENDO TO ZERO which also brought... your attention!!! Great! :o
