Please add MIDI "Program Change" to the playback "Instruction Syntax". For internal Vst' and external MIDI output.
Something like:
Valid values for type: note-on-prefix note-on-suffix note-off-prefix note-off-suffix Valid values for (Program Change), Most Significant Byte_(MSB) Least Significant Byte_(LSB) values: Integer's between 0 and 127. Effect: MIDI "Program Change" and "Bank Select". Used for both internal vsts and external MIDI output. This would be a good addition to Notion. Lots of 3rd party vst' respond to MIDI Program Change messages. This will also free up the use of "Channel Change" which is quite limiting compared to the MIDI Program Change matrix. ,Johnny ![]() |
