Please add MIDI "Program Change" to the playback "Instruction Syntax". For internal Vst' and external MIDI output.
Something like:
    Instruction syntax: < program change="xxx" MSB="xxx" LSB="xxx" />
    Valid values for type:
    note-on-prefix
    note-on-suffix
    note-off-prefix
    note-off-suffix
    Valid values for (Program Change), Most Significant Byte_(MSB) Least Significant Byte_(LSB) values: Integer's between 0 and 127.
    Effect: MIDI "Program Change" and "Bank Select". Used for both internal vsts and external MIDI output.
This would be a good addition to Notion. Lots of 3rd party vst' respond to MIDI Program Change messages. This will also free up the use of "Channel Change" which is quite limiting compared to the MIDI Program Change matrix.
,Johnny
:arrow:
by wcreed on Sat Sep 06, 2014 7:19 am
Bill Reed
Notion 6, Sibelius 8.4, Finale 25, Overture 5, Cubase 8.5
Win10 x64, 32GB RAM; iPad2; Focusrite Scarlett 18i20
Kontakt, VSL VI Pro, VE Pro, EWQL Orch, Choirs and Pianos
by martinkutschker on Wed Jan 21, 2015 2:58 pm
