Hello!
Is there a keyboard shortcut to change voices on Notion? I have been looking at the shortcut sheet (available through the application), and I cannot see a listing to a shortcut to switch voices. Thanks. |
Never mind. Found this in the manual (should be added to the shortcut listing)
"To switch to Voice 2, press [Windows: Ctrl + 2; Mac: CMD+ 2] or go to the Entry Palette and click third pane from the left . To verify you have multi-voice entry enabled and you are in Voice 2, you view a small v2 mark in your Music Cursor . Switching to Voice 2 triggers two events: all succeeding notation you Enter appear as Voice 2 (stems down) . At the same time, every time you add a Voice 2 note, any Voice 1 note(s) in the same beat that happen to have stems down now have their stems pointing up . In the example below, Voice 2 notes have been added to only the first half of the measure: note how the upper F in beats 1 and 2 point upward ." |
Users browsing this forum: No registered users and 17 guests
