I am trying to make a piano staff look less complex timing wise by turning 32nd notes into grace notes. See measures 26-31. Also how do you change a tied eighth-half-eight into a dotted half note.
I will attach file. Thanks
Hello,
For the grace notes, drag a box around the notes you want to change to grace notes, if using Windows, Right Click on the selection > Notes > Grace Notes. However, that will mess up your measure timing because they are not notes with real rhythmic value. I don't know of any shortcut to switch between ties and note values without deleting the tie and then manually adjusting the note length value. |
