If I bought a VSTi library (Swam Saxophones) that says it supports" AAX, VST2, VST3, AU" will that work from Notion 6 for Windows?
In other words, does 'VST' in Notion support VST2 and/or VST3? Thank you. EDIT: I think I found the answer from a forum search. VST3, no support. Here is a comment from Michael Myers: The first thing you need to do is make sure that the VST2 version of VEP is enabled in Notion's Plug-in Manager window. Notion doesn't recognize VST3 or other forms of plug ins so check that. Once you've enabled it, it should show up in the list of available plug ins in Notion's Score Setup window, ...
Notion only supports VST2.
with small AOC monitor for additional display macOS Ventura 13.4 2 - 500 gb + 2 - 1 tb external SSD for sample libraries M Audio AirHub audio interface Nektar Panorama P1 control surface Nektar Impact 49-key MIDI keyboard Focal CMS40 near-field monitors JBL LSR310S subwoofer Notion 6 + Studio One 5 Pro http://www.tensivity.com |
Users browsing this forum: No registered users and 17 guests
