Hello all.
I've searched for a solution to this and came across the old forum which says, select your group of notes, press the "=" key and then select your time value from the menu but "=" didn't bring up a menu. Could anyone guide me ? I just want to change a group of 32's to 16's as I've entered them wrong. 🙄 Ta Colin. |
There's no menu or dialog involved. Select the notes, hit the equal key and then immediately hit the W, H, Q, E, S, or T key for the new time value desired for the notes selected.
colinmold wroteThanks Michael. Should work. Make sure you're in edit mode (the little conductor icon is gray, NOT blue).
An update Michael. if I leave caps lock on, select the notes, press = followed by S to change the 32's to 16's. Nothing happens. If I turn caps lock off, select the notes, press = followed by Shift + S, that should equate to the same thing but my mouse pointer changes to a slur. Is it related to the menu I have active or something ? I have a note value sub menu active
PS I have now located section 10.5 of the user guide which says exactly what you've told me. |
Curious. On my system, I get the same behavior regardless of caps lock or not. I hit =s and it changes selected notes to sixteenth. If i do = shift s, i get the slur. I use that keyboard shortcut all the time, shift s gives me a slur.
Sounds to me like an oddity with your system or maybe your keyboard settings. Might want to submit a ticket to Notion support.
colinmold wroteAn update Michael. if I leave caps lock on, select the notes, press = followed by S to change the 32's to 16's. Nothing happens. If I turn caps lock off, select the notes, press = followed by Shift + S, that should equate to the same thing but my mouse pointer changes to a slur. Is it related to the menu I have active or something ? I have a note value sub menu active. As best as I can determine, you are doing this on a Windows machine? THOUGHTS I searched your posts and found one where you referred to "ctrl-D (PC)", which is why I am guessing you are doing this on a Windows machine, which is fine . . . michaelmyers1 is on the Mac-like me-so there are differences, where for example the Mac has a "control" key but no "ctrl" key, and "ctrl" on a Windows machine maps to the "command" key on a Mac . . . This could be due to the type of mouse, trackpad, Watcom drawing tablet, or other mouse-like device you are using, or it could be something else . . . Some of the shortcut and hotkey combinations are different on Windows machines . . . Generally, everything on the Mac is the same for everyone--with the exception of the language one selects with respect to the keyboard, where for example German keyboards have a different layout and characters from English keyboards, mostly due to German having things like umlauts and characters that are not on an English keyboard . . . [NOTE: On German and other international keyboards, note duration values are numbers rather than characters like on an English keyboard (actually an American keyboard, but so what) . . . ] Whether it matters is another topic; but I think it's a general rule that you can do everything NOTION does regardless of whether your computer is a Mac or a Windows machine . . . One thing I noticed, which on the Mac is a bit non-standard, is working with "caps lock" ON . . . I nearly never use the "caps lock" key on the Mac . . . Lots of FUN!
Surf.Whammy's YouTube Channel
Thanks for your replies folks Yes I can confirm I'm on a Windows 10 machine. I wish these days that I was using a Mac I'm fed up with MS Windows but that's another story. Can't afford to change at the moment.
Well, based on your responses, I'll have a play around with it this evening and see if I can solve the problem. ttfn |
And the answer is, the keyboad mapping of US vs UK although having worked with Terminal Emulation software before I thought "=" + "s" would have been the same with a US keyboard as it is with a Uk keyboard. Don't really get that. Anyway it's all clear in the short cuts document below. Mine keys are 5-0
I shall keep the shortcuts .pdf open in future as it'll help. |
I had thought at one point that it might be keyboard mapping.
At least you got it figured out!
Yep all good Michael, although having changed my 32s to 16s it joined that group with a beam to the following group of 32's I had yet to change. When I tried to remove that beam, the program crashed but that's another topic I think. At least we got to the bottom of the main issue even if I'm still no better off . I'll probably just start again. Cheers.
