Adding multiple Copyright fields
Posted: Mon May 06, 2019 1:26 pm
by willphillips2
Is it possible to add more than one copyright field to a score? I have been working on an arrangement that contains a rather lengthy copyright that requires 3 lines of text to fit on the page. I can't simply press Shift+Enter like one would expect. When I try to add a 2nd copyright line, it deletes the first one... In the past, I have used the subtitle text field as a make-shift extra copyright line, but in this case I already have all the editable header/footer fields used up. Any ideas?
Re: Adding multiple Copyright fields
Posted: Mon May 06, 2019 9:42 pm
by michaelmyers1
Not currently possible in Notion. Best bet is to add this via a PDF markup tool after printing the score to PDF..
Posted: Thu May 16, 2019 10:18 am
by willphillips2
Bummer!
Ultimately, my solution was to put full copyright info on a title page, with an abbreviated copyright on the score/parts. Hopefully that fulfills publishing requirements. Otherwise, I'll be using your suggestion.
Thanks!
