Hello,
I'm probably doing something not quite right, but a simple MIDI drum pattern, Kick (C1), Snare (D1), and Closed HiHat (F#1) still appear as standard notation when using the S1 Song menu>Send to Notion function. It doesn't matter if the music editor is in melodic or drum mode.
Changing the score setup in Notion to Drum Set notation doesn't change anything.
Has anyone successfully completed the transfer?
Edit 1/16/19: A support ticket was submitted.
2017 MBP/2012 Mini, macOS 10.4.5, S1 4.5.1, Notion 6.5, Faderport 2018, Eris 5, USB-C Studio 24c, silverface Apollo Quad-TB, Integra 7, MIDI guitar controllers, Novation SL MKll for CC - no Automap!
by CSeye on Wed Jan 16, 2019 8:36 pm
Brian from tech support provided the solution. Name the S1 4 track Drum Set before the transfer. It works perfectly. :thumbup:
DRUM SET, drum set, Drum set, etc. will result in drum notation in Notion.
by bartbalint on Wed Jan 23, 2019 7:10 am
I noticed this same issue. Thanks for posting this answer!!
Studio One v4.5.2, Win10 1903, Quantum2, Focusrite Scarlett 18i20, Focusrite Scarlett OctoPre, Yamaha Motif6, MCU-Pro, Wacom pen tablet, ATOM, GR55, Focusrite ASA one, HPD-20, Mackie Big Knob, 8-)
by tonyward2 on Fri Jan 25, 2019 6:42 am
Is there a list of all the track names that Studio One will recognise and auto map?
by CSeye on Fri Jan 25, 2019 3:39 pm
tonyward2 wroteIs there a list of all the track names that Studio One will recognise and auto map?
Drum notes in S1 need to be assigned to General MIDI (GM) drum note values.
The Presence drum kits: Basic, Classic Rock, Standard, etc. follow the GM drum map and will result in drum notation in Notion.
Impact drum kits aren't consistently aligned with GM maps. In the Detroit kit for example, C#1 is assigned to a clangy-sounding Hat Pedalo (vs.snare Side Stick) and E1 to Kick Breach (vs. Electronic Snare).
Notion interprets the C#1 as snare side stick notation and E1 as an alterate snare drum sound.
I'm still exploring how this works with Addictive Drums 2 and NI drums and will document results here when sorted out.
by CSeye on Fri Jan 25, 2019 8:30 pm
bartbalint wroteI noticed this same issue. Thanks for posting this answer!!
Good to hear the solution is useful to others.
Cheers!
by CSeye on Sat Jan 26, 2019 5:43 pm
Looks like the conversion of S1 drums to drum notation in Notion requires a S1 drum kit - Impact or Presence.
Drum notation in Notion does not occur when using a third party drum kit plug-in in S1 such as Addictive Drums 2 or the NI drum kits. Setting the internal mapping of these instruments to GM doesn’t help, even if the MIDI notes on the S1 Instrument track conform to C1-kick, D1-snare, F#1-closed hat, etc.
I’ll continue to use AD2 because it sounds great! When I need drum notation, then a Presence drum kit on a separate track will be used for the note conversion.
by Andrew Hazzard on Mon Feb 18, 2019 12:17 am
Thanks so much for posting!
by roland1 on Mon Apr 15, 2019 6:25 pm
Damn. I was looking for an answer for how to get my V-drum tracks into notion as proper drum notation only to find out that it won't work for Slate Drums or other third party vsti mapping - unless you remap them to be GM, I suppose.
I should have remained in my career as a nuclear physicist. Mentally, it was far less demanding. :)
I use: Studio One Pro v4.53 on i7 7700 win10 PC w16GB RAM and Mac Pro Tower (Sierra) w/RME & Focusrite interfaces.
Author: Reality Checks for Everyday Life — Keeping it real in a world of illusions. I can also be found loitering at: http://RolandK.ca
Attention all shoppers: The people in commercials are paid actors pretending to like the product. It's easy to forget that fact with the music blaring and their happy smiles flashing.
