More or less all in the subject.
Being a modest musician, I use scores which could fit only on one page. But Notion seems to automatically reserve the upper part of the page for Title-Dates, etc.. which I don't need, not peforming, or even training with others. Is there a way to have the beginning of the notes starting from the top of the pages, like 2 cm above or stg? Thank you so much and Happy New Year. Etienne |
1. Delete all unwanted titles, composer etc by selecting them and using <delete> key (they can be added later if needed).
Then either: 1. Under <View> menu, select <Show Layout Handles> or use <command/ctrl L> 2. Grab the square to the left of the first staff and move it to the desired location. OR (this is probably the easiest method): 1. Under <Score> menu, select <Full Score Options> 2. Under the <Page> tab, change the <Top, First Page> margin to your desired margin size.
It doesn't seem I have the first option ("handles..."). Maybe it's a N6 option?
And I had tried to work out the margin, but sofar, no success. I found a turnaround. Starting from the second page, creating a lot of empty staves. Ok for printing at least (I select only p2. ). Not so practical but well... Thank you for your time), still. |
Etienne, yes, sorry, Layout Handles were added in N6.
The page margin option should work though as well. It always worked in every version of Notion I worked with.
Users browsing this forum: No registered users and 24 guests
