So, I'm having an issue where I'm entering notes on a drum part on a big band score and everything from the point of editing mutes, except the piano. I'm really pulling my hair out over this as I have to choose between editing my drum part or having playback!
The mixer is not muted.
The sounds are notion's own vst
It seems to only happen on certain bars, usually when I have two notes on a single stem.
The effect is reversed when I delete the bar causing problems in the drum part.
I'm not sure if I will have much luck pinning this down, as it seems so random...
by danielharris on Wed Oct 17, 2018 1:04 pm
edit: It's now doing it with single notes on a stem!!!
by danielharris on Wed Oct 17, 2018 1:08 pm
Now it crashed and I lost it all, just the kit part though... oh well, I'll try again and hopefully I will see different results...
It would be interesting to know if this has happened to anyone else!
edit: The problem hasn't resurfaced, thank god, hopefully it had something to do with the crash and the report helps!
