I have been using the shift+space+#+R for looping but I just tried entering the number 10 (no number pad) OS X El Capitan Ver 10.11.6 and it won't do the looping. Here is what I do:
Select the tenth measure (final measure) then shift +space the upper numbers on the keyboard 1 and 0 then the R. But it will not loop. If I use single numbers it loops successfully. Any idea how to over come this problem? Thanks |
Hi Robert.
(8) eight measures is the maximum limit for repeated loop sections in Notion. But when I need to listen to a longer portion of a score repeatedly in order to make edit decisions I insert temporary barline repeats with a setting of 99x. And a temporary rehearsal mark to use as a temp bookmark? Then simply delete them when I'm finished. The computer keyboard shortcut is a single colon symbol [ : ] and 2x [ :: ] for the end repeat. Double click on the end repeat barline to open it's dialog and enter the number of times to repeat. ,Newberry |
