Is there any way to have a different note spacing than "space evenly"? It would look way more professional, if one could use spacing options, where the space after a note is indicative of the note value (for example by using the fibonacci row or one of the other ways this is usually done). Even when just writing a lead sheet this is noticed immediately.
In NOTION 6, you can adjust the layout of notes by repositioning measure sizes . . .
THOUGHTS It's not totally adjustable on a note-by-note and phrase-by-phrase basis, but you might find that it helps . . . You also can adjust note stems and the placement of articulation marks . . . Ditto for dynamic marks, where the general rule is that they all need to be below the staff . . . Lots of FUN!
Surf.Whammy's YouTube Channel
