50 postsPage 3 of 3
1, 2, 3
I composed a new harmony and counterpoint melody for Realivox Blue's singing and now it fits the song, which mostly was just a matter of getting in touch with my "inner liturgical choirboy" . . . :+1
I need to listen to it a while, but I think Blue's singing is coming along nicely now . . .
There is a new, longer ending; and the second half of the song has Blue singing a few more notes and phrases . . .
This continues to be the second Studio One Professional ".song" layer; and the NOTION 6 score now has 23 ReWire MIDI staves . . .
The audio stems from the first ".song" layer are in this ".song" layer, and there are 12 virtual instruments (a combination of AU and VSTi) hosted in the second Studio One Professional ".song" layer, which is fine . . .
One of the 12 virtual instruments is Kontakt 5 (Native Instruments), and it's loaded with Realivox Blue . . .
The music notation on the respective ReWire MIDI staff in the NOTION 6 score is telling Realivox Blue which notes and phrases to sing. The phonetic script for Realivox Blue is in Kontakt 5, and at present there are two phonemes ("zah" and "tah")--which together map to "zot"--although a good bit of the time Blue is singing only the "zah" phoneme . . .
The Surf Whammys
by Surf.Whammy on Sat Jul 07, 2018 1:29 am
I do nearly everything "by ear" but in a smart way that's balanced by a bit of music theory whenever it's useful, which is more often than one might imagine . . . :)
This is the new version of "Surf Zot", and it has new counterpoint for Realivox Blue (Realitone) that is tighter and fits the song . . .
It also has enhanced echoes on Realivox Blue done with some modifications to the FabFilter Software Instruments "Timeless 2" echo unit; and I made some changes to the ending . . .
I listened to the previous version ("V17") quite a few times; and the most obvious "by ear" thing I noticed is that Blue was starting too late most of the time; so in this version I added some 1/8th and 1/16th notes to start her singing sooner rather than later . . .
The counterpoint is more melodic in this version; and I think it fits the song better . . .
Getting the starts of notes at the right times makes Blue's singing tighter, which is important because rhythm guitars and drums usually are precisely on the beat--except when they are doing syncopated rhythms . . .
Coming up, I am planning to add an explosive rhythm guitar based on the rhythm guitar sound I heard on a Metal song a few weeks ago on iHeart FM radio in their weekly "Metal Madness" program . . .
I don't know the name of the song; but (a) it's a distinct rhythm guitar sound and (b) I think I know how to create it with a combination of AmpliTube 4, SampleTank 3 (IK Multimedia), a noise gate (TrackPlug 5 [Wave Arts] or Pro-C [FabFilter Software Instruments]), and whatever else is required . . .
On a related note, prior to adding Blue, the song was focused heavily on electric guitars; but now that Blue is singing what she needs to sing, the emphasis on the electric guitars is softened a bit, which essentially makes it a simple three-chord song {A, D, E} with an interlude . . .
In turn, this makes it easier to compose a vocal melody . . .
On the lyrical side, mostly what the Aliens From Outer Space are beaming me is {monkeys|weasels}; but my job is to do, not to judge . . . :P
The Surf Whammys
by Surf.Whammy on Fri Jul 20, 2018 7:06 am
I consolidated the instrument and audio tracks for the current version by doing some submixing and then created a new ".song" layer in Studio One Professional . . . :)
There are a few changes in the counterpoint harmony Realivox Blue (Realitone) is singing; and I added a second Realivox Blue harmony to the ending . . .
I also adjusted the volume levels for the drumkit and primary lead guitars . . .
It's been a while since I did any submixing in Studio One, so I forgot how to do it; but after a bit of reading I found a way to do it, although I have no idea if it's the best or smartest way; but so what . . .
Along the way, I discovered that Studio One keeps copies of everything; and this was causing some problems when I did mixdowns of selected tracks; so I deleted all the history and then everything worked as expected . . .
I also noticed that I had recorded the MIDI sent from NOTION via ReWire MIDI for Realivox Blue, which also was a problem, because it was different from the changes I was making in NOTION; so I deleted the recorded MIDI and then everything was good . . .
For some not entirely known reason, the mixdown for a section of electric guitars (tremolo and echo metal) also had an audio track for Realivox Blue, even though I did a separate audio track for Realivox Blue; but after listening to it, I decided to keep it as a bit of serendipity, since it adds more echoes to what Realivox Blue is singing, and I like echoes . . .
In this version, there are a total of 23 instruments--23 ReWire MIDI staves in the NOTION score, which continues to be the only NOTION score, so far . . .
The audio is submixed to eight (8) tracks; and at present this is all that is in the "Layer 3" Studio One ".song" . . .
Four (4) of the submixed tracks are from "Layer 1", and the other four (4) submixed tracks are from "Layer 2" . . .
The plan at present is to record an explosive rhythm guitar and some prototype lyrics about a weasel and a monkey, which probably will be something like this:
The weasel hurled lies at the monkey to make it go away
But the monkey blocked the lies and now the weasel's going to pay
This is what the Aliens From Outer Space beamed me, so it's not my fault . . . :P
The Surf Whammys
by Surf.Whammy on Sun Jul 22, 2018 5:01 am
I added two Metal sections to "Surf Zot" (before and after the Interlude) . . . :)
This took about eight (8) hours, including the time to compose the music notation for the "Metal Monkey" sections, which is fine with me . . .
I used the Studio One Professional ".song" for "Layer 1" to record new Drumkit. Höfner Bass, Rhythm Guitars, and Lead Guitars for the "Metal Monkey" sections, with structural modifications done in Studio One and NOTION . . .
This is done with a clone of the original "Layer 1" Studio One ".song", which then was saved and modified . . .
The NOTION score also is cloned and saved with a new name; and structural changes were made to the clone . . .
The new "Layer 1" uses the existing instruments for the Drumkit, Höfner Bass, Rhythm Guitars, and Lead Guitars, which (a) makes it easier and (b) keeps the Drumkit and Höfner Bass consistent throughout the song . . .
Everything for the most recent version of "Surf Zot" (V19) already is recorded; so the new version just needed to be edited to separate the submixed audio tracks to make space available for the "Metal Monkey" sections, which also was the case for the cloned NOTION score, where for the NOTION score it's just a matter of inserting some number of empty measures--empty measures for the "Metal Monkey" sections and a set of empty measures for the already recorded "Interlude" section . . .
[NOTE: In Studio One terminology, this is called "splitting stems" . . . ]
There cannot be music notation in the cloned and modified NOTION score for the already recorded audio, because I am using different music notation to play the same instruments, albeit with a few modifications to the Rhythm Guitars and Lead Guitars . . .
I was not planning to work on a Lead Guitar part for the "Metal Monkey" sections, but the Aliens From Outer Space beamed me some music notation; so there's a Lead Guitar melody that fits nicely . . . :+1
I ran the new Lead Guitar through a FabFilter Software Instruments "Timeless 2" syrupy echo unit, and then added music notation for more "echo notes" to the Harmony Guitar, which uses the same SampleTank 3 (IK Multimedia) legacy instrument and the same syrupy echo unit . . .
[NOTE: I like the SampleTank 2 legacy instruments; so I imported them to SampleTank 3 where they work nicely in 64-bit mode . . . ]
I probably will add a Synthesizer or something to smooth the transitions to and from the "Metal Monkey" sections; and I might use Reason (Propellerhead Software) to do this . . .
The Rhythm Guitar at far-left is not so explosive, but so what . . .
After I listen to the new version a while and start doing the "Metal Monkey" vocals, I will work on the Rhythm Guitar . . .
The Surf Whammys
by Surf.Whammy on Tue Jul 24, 2018 6:41 am
Repetition is good, but too much repetition is not so good . . . :)
After listening to the new "Metal Monkey" version of "Surf Zot" a few times, I decided that there were too few fast sections and too many slow sections; so I changed the song structure and made a few changes to the lead guitar phrases in the "Metal Monkey" sections . . .
The "Metal Monkey" sections have the most energy; but the original slower sections are more melodic; so from the perspective of managing audience behaviors, it makes sense to have a "big ending", which in this instance maps to ending the song with a "Metal Monkey" section . . .
It's important for a song to have a distinctive start and a "big ending", mostly because this is what people remember first . . .
The primary focus for this version was the song structure; so I need to do some producing and audio engineering, which is the way it works here in the sound isolation studio . . .
The Surf Whammys
by Surf.Whammy on Tue Aug 28, 2018 8:27 am
Over the past few weeks the Aliens From Outer Space have been beaming me bits and pieces of lyrics for the "Metal Monkey" sections of "Surf Zot", which is the way it works when you have the required communication chip installed in your brain . . . :+1
After considerable pondering, I realized that the overall sparsity of lyrics beamed to me by the Aliens From Outer Space was a puzzle designed to lead me to the realization that the "Metal Monkey" sections are lyrical variations of the 19th century nursery rhyme, "Pop Goes The Weasel", mostly because it's about a monkey and a weasel . . . :P
Now that I have some additional lyrics, I modified the music for the "Metal Monkey" sections (a) to fit the sparse lyrics and (b) to add a "big ending" during which I will scream something along the lines of "I'm A Metal Monkey", since based on listening to the iHeart "Metal Madness" radio program, screaming is "big" among the so-called "Youth of Today", as are beat changes, illogical segues, and a virtual festival of strange and chaotically random spurts of electronic noise . .
And while I have not started adding the festival of strange and chaotically random spurts of electronic noise, it's part of the plan . . .
It's true!
Along the way, I upgraded to Studio One Professional 4 (PreSonus) and Reason 10 (Propellerhead Software), so this new version of "Surf Zot" is done with Studio One Professional 4 . . .
And I changed the far-right rhythm guitar in the "Metal Monkey" sections so that it doesn't sound like a whistle or a siren . . .
[NOTE: I plan to record some lyrics, but at present this is the instrumental version, except for Realivox Blue (Realitone) singing during the more melodic sections of the song. Sometimes a melody appears first, and then I do the chords and lyrics; but for the "Metal Monkey" sections, it's a different order (chords, lyrics, melody); and this version fits the chords to the lyrics . . . ]
The Surf Whammys
by Surf.Whammy on Sat Sep 01, 2018 3:29 am
I'm getting ready to do a vocal sketch for the "Metal Monkey" sections, and I want to "duck" some of the instruments so I can hear what I'm singing (or screaming, depending on what my mood happens to be at the time) . . . :)
I want to use Pro-C 2 (FabFilter Software Instruments) for "ducking", and after a bit of experimenting I discovered how to get it working nicely in Studio One Professional 4 (PreSonus) . . .
At first, I tried it when there were external devices in the Studio One project, but instead of tracking the audio level, it tracked the volume slider position, which as best as I can determine is a MIDI "feature" . . .
I don't want Pro-C 2 to track the volume slider position, so after some experimenting I discovered that by removing all the external MIDI devices, everything started working and instead of tracking the volume slider position, Pro-C 2 tracked the real-time audio level of the vocal microphone, which is what I need it to do . . .
Since there is no documentation on using Pro-C 2 with Studio One Professional 4, I decided to make a YouTube video to show how it works . . .
And because "Surf Zot" is using ReWire MIDI, everything is good . . .
ReWire MIDI is handled by Studio One Professional 4, NOTION 6, and the ReWire (Propellerhead Software) infrastructure separately from "old school" MIDI, which is excellent . . .
On a related note, the Aliens From Outer Space beamed me two new verses for the "Metal Monkey" sections, which combined with the other already beamed verses is a complete package . . .
I awoke a little while ago and currently am in what one might describe as an "Almost Human" (KISS) state of mind, so there's no telling what the vocal sketch will be . . . :P
I have been drinking very strong coffee, but I can control whether I awake fully, and at present I am maintaining a dream state by design--in part, because I don't have an actual melody for the lyrics in the "Metal Monkey" section, hence am doing it in real-time on the fly on the first take, or thereabout . . .
It's a sketch, so it's all good!
The Surf Whammys
by Surf.Whammy on Sat Sep 01, 2018 7:32 am
I did the vocal sketch for the "Metal Monkey" sections and recorded it . . . :)
Except for doing a bit of vocal practicing while I was selecting and configuring the vocal special effects, I did everything in real-time on the fly, which included devising a melody as I sang the lyrics to record ti . . .
I did the "Metal Monkey" verses first, with the plan to record the screaming after I recorded the verses, but as I was configuring the special effects for the "Metal Monkey" tags, Pretend Johnny Cash appeared and did a one-time cameo, which I duplicated and pasted two more times . . .
And I changed the far-right rhythm guitar to a more classic Stratocaster rhythm guitar sound . . .
Doing this with Studio One Professional and NOTIION makes it very easy, and I like this strategy . . .
There are several Studio One ".song" projects and two NOTION scores, all of which is very convenient . . .
The Surf Whammys
by Surf.Whammy on Sun Oct 07, 2018 11:32 am
The Aliens From Outer Space beamed me lyrics for the slow parts at the start and after the slow interlude . . . :)
I did the composing and singing mostly in real-time on the fly . . .
The current plan is to double or triple it on more tracks, since at present I am not sufficiently familiar with the vocal melody to transcribe it to piano, which makes it even more of a sketch than the other singing and lyrics (which I now like) . . .
I increased the volume level of the Stratocaster rhythm guitar at far-right; and I adjusted some of the echo units . . .
The new vocals are close enough for doubling and tripling, and some of the phrases are nice and do not need to be changed . . .
P. S. I know the new singing is really bad, but I thought it might be a self-confidence and self-esteem boost for someone--for example everyone in the known universe . . . :P
Here in the sound isolation studio getting everything onto the "good" side of the equation mostly is a matter of becoming Pretend George Martin for a while and encouraging the choirboys to do a bit of singing practice, during which they might find the correct melody, which is fabulous . . .
Fabulous! :+1
The Surf Whammys
by Surf.Whammy on Mon Oct 15, 2018 11:53 pm
Pretend George Martin made me practice singing the slow parts for a while, and then I recorded new singing with some changes to the lyrics . . . :)
I like this version, and other than perhaps doing some fine-tuning to the producing and adding some "in-and-out" sparkles and twinkles, I think it's good . . .
At present, I am not planning to do anything else to the interlude in the middle of the song, but I think letting Realivox Blue (RealiTone) have a bit of FUN with the "Rita Rage" concept makes a bit of sense in the interlude . . .
On a related topic, I think virtual mixing boards (a.k.a, "consoles") have particular sonic characteristics in the same way that physical consoles do . . .
This makes sense, but it's not something on which one focuses in an immediately conscious way for a while . . .
I first noticed this when I got Logic Pro 9 (Apple) and was able to compare it to Digital Performer (MOTU) . . .
I prefer the way Digital Performer sounds when mixing to the way Logic Pro X sounds, and Digital Performer for me is easier to use . . .
More recently, I have switched to Studio One Professional, and I particularly like the way it sounds, since (a) it's crisper and (b) it's what I call "more tolerant" when you add more tracks . . .
It's "more tolerant" in the sense that you don't need to readjust everything, and I think this partially is a matter of headroom but also is the result of the way the audio is processed internally . . .
I continue to use a lot of effects plug-ins; and since they make sense to me, it's easy to adjust them based on the way the Studio One Professional 4 mixing board (or "console") behaves . . .
The Surf Whammys
50 postsPage 3 of 3
1, 2, 3
