Here's my problem, this is what the Notion manual says : By default, each tap of an NTempo key corresponds to the pulse of the meter (examples: a quarter note in 4/4 But in my case, when i'm in 6/8, each tap corresponds to a quarter note (as if i was in 3/4) as you can see it here : Can you please help me and tell me what did I do wrong ? Thanks |
Hello Annibale
You need to add the eighth notes to the NTempo Staff. Below is from the Notion 6 Help>User Guide page 4.9 The notes you place on this track determine Hope this helps. ,Newberry |
To add to John's post: you can add just a single eighth note as the first note on the nTempo staff. If the tap rhythm never changes, then no need to add more notes. If you want the tap rhythm to change at some point (I have never done this but you might) then add a new note or notes.
