I've looked through the previous "Metronome not working" posts and none seem to match my situation. I have one Mac running Sierra on which Notion 6's metronome works fine both in recording and playback. I have another Mac, also running Sierra, on which Notion 6's metronome isn't working. I've checked the metronome wav files on both systems and they are identical. The install is identical. I'm open to suggestions as to what to try? Trashing some plist file or something? I've done a complete reinstall of Notion 6 on the machine on which it's not working and that doesn't fix it either. The clave track idea is a sort of workaround, but intrusive to workflow. Sometimes I want to fire up Notion to capture an idea immediately from my MIDI keyboard and I don't want to have to set up a click track first. Any ideas? Kind regards Derek.
Derek Jones
MacBook Pro 17" 16GB,15" 12GB,Sierra, MacBook 13",12GB HighSierra. SSD,Windows 7 64 8GB RAM, Win 10 64 Pro 64GB RAM, [email protected] Notion 6.5.470, Studio One 3.5 & 4.X Pro Tools 2019.5,Logic Pro X 10.4,Cubase 10,Ableton Live 9.7.6,Reaper 5,Tracktion 7 Sibelius Ultimate 2019.5,Finale 25,Overture 5,MuseScore 3 Vienna Ensemble & Instruments 7,SE Strings,EWQLSO & Play 6,Miroslav Philharmonik 1&2,Kontakt 5.8.0,Waves 10 16.0.2 FW,iConnectMID4+ on macOS (+ others aggregated),192 Mobile+DP88 on Windows |
I fixed it! Thankful!
Here is what it was. As one can trash the cache file for the Plugins, which I've done before to rescan the plugins, I was looking in the same dir, which, on macOS at least is under: Library/Application Support/Notion Music/Notion 6 and, I noticed there is also a file called SamplerDef64.cache and I got to thinking... (you know, as one does, as it all percolates ) Sampler... Sampling... Samples... Metronome samples... Ohhhh! Huh. Then I checked the size of that file, compared to the other two systems I have 6 installed on, and... it was significantly different. So, after making a copy of that file in case I ruined things, I removed it, and then restarted Notion and .... It works! Yea! Thankful for that. Now I can record again. Cool
Derek Jones
andrewpink wroteI know it's an old post but you just helped- same problem, thanks! Andrew, I'm delighted to see that our old friend Derek's posts are still helping folks. Sadly, Derek passed away a few months ago. We miss him around here!
with small AOC monitor for additional display macOS Ventura 13.4 2 - 500 gb + 2 - 1 tb external SSD for sample libraries M Audio AirHub audio interface Nektar Panorama P1 control surface Nektar Impact 49-key MIDI keyboard Focal CMS40 near-field monitors JBL LSR310S subwoofer Notion 6 + Studio One 5 Pro http://www.tensivity.com |
andrewpink wroteHello Michael, Andrew, I don't think you upset anyone. I just wanted to note for the benefit of all of us how Derek's generosity with his time and help lives beyond him! I think he would be very pleased to know that his posts continue to help others.
