Hello, I've been working on a score in Notion and I need a good way to switch to the VSL portamento articulation for an entire phrase. I've noticed that Notion works better than Sibelius when it comes to playing portamento between just two notes, but that there is no "Port." technique to switch over to the portamento technique for a longer sequence of notes. Putting a slide between every note in the phrase does not create the desired effect. Neither does inserting a keyswitch on the staff. I've also tried creating a rule to set a flag for the articulation change, but unsetting the flag has no effect and the articulation remains portamento. I'd like a way to simply switch over to the portamento articulation for several notes and then switch back. Any help you can offer is appreciated. Thanks.
