Turning to the Beginning of a score Question.
Posted: Thu Aug 03, 2017 6:07 am
by robertthompson1
Screen Shot 2017-08-03 at 8.03.02 AM.jpg (12.24 KiB) Viewed 4461 times
When I play thru all the bars of my score, playback stops but when I then hit Delete(Mac Backspace) once or twice nothing happens. I thought it was the shortcut for return.
Why does this not work? Is it a Bug?
Thank you.
From the Manual: After you stop playing a score:
> Press Backspace once to return to last place you started
> Press Backspace twice (or Home) to return to beginning
Re: Turning to the Beginning of a score Question.
Posted: Thu Aug 03, 2017 7:47 pm
by michaelmyers1
This works as advertised on my Mac with both wired and wireless keyboards in N6. But I recall if I was using my wireless keyboard with N5 or earlier I had to use fn and (back arrow) to get this to work instead of delete. Maybe they fixed it in N6, or it was a macOS correction.
Posted: Thu Aug 03, 2017 8:39 pm
by robertthompson1
Yes using fn+< (left arrow) is the only thing that works unless I stop playing with the delete then it works as expected but not after a play thru. Then only fn and left arrow key.
Posted: Sat Aug 05, 2017 12:18 am
by michaelmyers1
Hmmm. Probably deserves a support ticket.
Posted: Sat Aug 05, 2017 7:02 am
by robertthompson1
How is a support ticket done?
Posted: Sat Aug 05, 2017 12:05 pm
by michaelmyers1
At the top right of this window, hover over your image, then select My Account. There's a tab there for support. Or, at the bottom of this window, way down, there's a link for Support.
Posted: Sat Aug 05, 2017 9:07 pm
by robertthompson1
Got it and send one. Thanks. :+1
Posted: Sun Aug 06, 2017 2:13 pm
by michaelmyers1
Working with this today and I realize that what I do mostly is single-click the back arrow at the top of the Notion score window (in the transport section) to return to the last place playback was started, and I double-click the back arrow to return to the beginning of the score.
I know this is not ideal for those who don't like to interrupt their workflow by using the mouse to click on things, but I find that while editing I use these buttons al the time.
Posted: Thu Aug 10, 2017 7:09 pm
by jasonchildress
I do the double-click with the mouse as well--I didn't even know about the keyboard command.
Posted: Tue Feb 05, 2019 3:37 am
by jacobtechow
Command + shift + home takes you to the beginning ;)
Posted: Wed Feb 06, 2019 10:15 pm
by michaelmyers1
Wow this is an old post. Since posting here before, I acquired an extended keyboard. Hitting Home takes you to the beginning if you have one.
