Hello,
I had a Notion 6 file where I was using a Waves demo and decided not to keep it. When I re-opened the file it gives me the error that it can't find the plugin. In the mixer section where the plugin was is an exclamation point in a yellow triangle showing the error. I just can't seem to figure out how to remove it. The is no dialog other than the error message when I click on the button. Any help would be greatly appreciated. Thanks, Troy |
The way to remove it from the file's mixer is to right-click on the plug-in and select None. This removes the plug-in from the file.
You could also go to Notion Plug-in Manager under the Notion menu and disable it in the list. And additionally, you can remove it from your system as well.
with small AOC monitor for additional display macOS Ventura 13.4 2 - 500 gb + 2 - 1 tb external SSD for sample libraries M Audio AirHub audio interface Nektar Panorama P1 control surface Nektar Impact 49-key MIDI keyboard Focal CMS40 near-field monitors JBL LSR310S subwoofer Notion 6 + Studio One 5 Pro http://www.tensivity.com |
It was really strange. I tried the right click and select none and it did not work. That fly-out menu never appeared on that instance. It worked on the others. I think it's a bug when there is an issues with a missing/corrupted plugin installation. When I trashed my Waves plugins and reinstalled them then the issue just went away. Go figure...
Thanks! |
