Hi folks
i just remapped some Keyboard Shortcuts of Notion4 in this week and i would like to share with u guys anyway, its not complete i cant find anything about those contain Ctrl/Shift..etc So, i use Autohotkey to help me (dont worry, thats a free software) such as clear velocity, set as tacet (i heard that current version of Notion5 is still not possible to edit shortcuts, u may want to try it on N5, i know thats still a KeyboardMap file in N5, so its probably more or less the same. i dont have N5 to test, sorry) ============================================================= ============================================================= Ok first of all suppose that u installed Notion with its default setting go to : C:\Program Files\Notion4\Support\Lists u can see KeyboardMap.tpk ( copy, in case u screw it up) open it with any text editor look for "Keyboard sequence"></property>" here's an example: <packet type="KBMP" name="Keyboard mapping"> pp means pressing p key twice changing pp within >< changes the Keyboard Shortcuts (a modified .tpk in attachment) i think u get the idea now, so...move on since some of the ideas are impossible to be done by editing .tpk so i called Autohotkey to help me http://www.autohotkey.com/ (first, download the software) Autohotkey's format is .ahk, which again can be opened by any text editor i read the official manual, and with Google's help, created the .ahk file in 2 days. (so im still a newbie...) just see my .ahk to get the idea(its also in the attachment, double click it to run) ============================================================ ============================================================ here's the List of Changes of my files: .tpk - pressing a note-value key twice will change highlighted-notes to that note value ( instead of pressing =q, =w, =e) (eg: press w/q/e/s/t twice; see Notion4 manual Chapter10.5) - press D key + note-value key will change highlighted-notes to the respective note value with dot (eg: press d+e, d+q) - press note-value key + R key to get Rest (eg: q+r , t+r) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ .ahk (the following keys are effective only if your window-focus is Notion4) - Capslock: activate Step-Time entry - A key: select all measures of a track (original Ctrl+shift+A is just a obstacle.) (u can still use Shift+A to get arpeggio without any problem) - Y key: paste insert (u can still use Shift+Y to use Rule-Set without any problem) - f2 Key: 'Files' menu - f4 Key: Set as Tacet for highlighted-notes ( doesnt work if no note is highlighted) - f5 Key: Make Tuplet ( doesnt work if no note is highlighted) - f6 Key: Remove Tuplet ( doesnt work if no note is highlighted) - f7 Key: Staff Setting Menu - f8 Key: Randomize Events Menu - f9 Key: Quantize to Notation - f10 Key: Clear Velocities - f12 Key: Dynamic Parts Menu ============================================================= ============================================================= thats it, any suggestion/bug report is welcome i hope u enjoy them Best. Yau
