File VE Strings Test - VSL SE Vienna Ensemble - hairpin dynamics work properly. See Meas. 114 in the following.
File: VE Strings Cello from MM.notion - hairpin dynamics are seriously messed up - full of the jitters. This is just one part of a score that is riddled with the issue - unusable. This does not seem to be a completely unknown issue: viewtopic.php?f=167&t=12513&p=68480&hilit=hairpin#p68480 The above thread is similar - no indication on how it was resolved. kmlandre made reference to " hairpin/dynamic attachment issues" in viewtopic.php?f=167&t=5510&p=27919&hilit=hairpin#p27919 What are " hairpin/dynamic attachment issues" and how do you if you have them and what is the remedy? Also, I attached a video showing the jitter in VSL. bp
Hello Bruce
I hope I understand correctly. Not sure what you refer to when you say "jitters" ? Try the edited Notion file of yours here. Or, edit your file by bumping up the first of the tied notes velocity level a small amount. In Notion. like any notation software, tied groups of notes are really one long note. The velocity of the first note is used for this long note event. Long story I'll try to make shorter I hope. With you example, when using Notion hairpins going from pp<FF the VSL sound engine can't open up to it's LOUDEST level completely. It's digitally controlled amplifier or DCA never receives the needed velocity of 127. The velocity range is 0-127. In Notion pp=40 as a default of velocity. The instruments Player or Engine is velocity dependent like most sample based VSTI's. I would be nice if Notion could compensate for this in some. Not sure how. That's another discussion. Most modeling technology VSTI designs don't have this retriggering problem in Notion. In Notion they can produce sound levels for "tied notes" from ppp < FFF >ppp <FFF -over and over- indefinitely using the first tied notes velocity level. - In Notion using most sample based audio engines their is only one solution I've found and it is an compromise. By setting the first tied notes velocity to a little higher level so that the DCA of the VSTI has more top-end volume range. But, then the low level becomes comprimized. It's probally then a little louder. So, finding the best of both is necessary. . i.e.What's most important at the point in the music? The low level pp ? or the FF ? Anyway, I hope this will help. Tell us what you came up with as your choice. ,Newberry |
[quote="johnnewberry"]Hello Bruce
I hope I understand correctly. Not sure what you refer to when you say "jitters" ? >> Dis you watch the video? cc 11 bounces, jitters... Try the edited Notion file of yours here. Or, edit your file by bumping up the first of the tied notes velocity level a small amount. Ah...this file plays properly, as I said...no tweaking required. The other file has hairpin jitters all through it. bp |
I don't have the VSL library.
Your upload of - VE Strings Cello from MM.notion ? I'd say it's corrupted in some way. Or I don't have something that should be loaded. When I load it the mixer doesn't have any control knobs ? Even after assigning an VSTI of mine. Couldn't get it to work for me. To narrow thing down, have you tried to start with a new Notion document ? ,Newberry |
johnnewberry wroteI don't have the VSL library. |
Bruce, I took a look at the MM file and corrected some of it. The problem was exactly what I had indicated to Christian in the older post that you refer to, plus at least one basic user error.
By the way, you didn't mention what version of Notion you're using, but when I opened the file, it was updated, of course, to v6. I hope there's no backward compatibility issues if you try to open the attachment in an older version. The first issue is a user error: In measure 1, you have a decrescendo starting on pp, to mp at measure 3. Mp is louder than pp, so you're asking Notion to do the impossible by decreasing velocity (or volume) from a soft note to a louder one. This makes no sense, and will certainly confuse the program as it tries to negotiate this backwards hairpin. I corrected that. Next, it's not always convenient, but for playback, Notion requires consistency in placement of dynamic markings. The next thing I did was to move all the dynamic markings to below the staff for page one, and it plays back beautifully now, using VSL instruments in Vienna Ensemble 5. I also did the same for measure 115 (I think you had the wrong measure in your post above) and it plays back nicely as well. For multi-voice measures, dynamic markings for voice 1 need to be above the staff, and dynamic markings for voice 2 need to be below. The dynamic markings at measure 60 (the one John shows a picture of above) are seriously whacked. Not sure at all what your intent is there, but that will never play back well, and I doubt a human instrumentalist could figure that one out either! Again, consistency is key. If you place dynamic markings above the line and others below the line, it will confuse Notion and playback will be affected. This is an unfortunate reality with Notion at this point, and the issue has been raised with the developers. I'm hoping to see some improvements in future releases. By the way, I never place dynamic markings on measure lines. I always place them on notes. I don't think that's a hard and fast rule, it's just something that I do, a personal preference. In the case of your file, I placed the initial dynamic marking of a hairpin on a note, and I left some of the ending markings on a measure. It works quite well. Another comment; not sure of your intent with the composition, but at a place like measure 81, since you told Notion to play p at measure 77, it will continue playing p until it encounters some other instruction. So there will be a jump after the single note in measure 81 as Notion jumps to the mp dynamic in measure 82. This may be your intent, but be aware that if you want a smooth transition, you will need a hairpin, or you need to place the mp on the single note in 81, or do something different. I always try to keep in mind that I'm instructing a machine what to do, and I try to be very consistent. Sometimes this means that I even have to duplicate measure markings for an entire piece both above and below the staff. Painful? Yes. Worth the effort? I think so. I hope this helps. Michael
michaelmyers1 wrote |
Just to close this out.
The issue is cured by putting all dynamics BELOW the staff. After some investigation, much to my surprise, this seems to be STANDARD....who knew? BP |
