[S1 3.3-N6] Studio One / Notion 6 Interoperability Guide
Posted: Thu Aug 25, 2016 8:09 pm
OVERVIEW
UCNET (Discover on network)
• Studio One can send Instrument track data to Notion 6 via new command "Send to Notion" via UCNet ( not Rewire). Notion will convert it to notation and open the new page in one click on Studio One. If Both Studio One and Notion have the same instrument it will share presets and you will hear it the same sound in Notion. This is useful to print the instrument data as notation.
• Notion can send notation to Studio One with a new commands Send to Studio One. It use UCNet as well and not Rewire. The Instrument data will show up in a track and have the same preset if they both know about the plugins, and you will be able to play the instrument in Studio One. This is useful to transfer part or all of a score over to Studio One for more refined mixing.
• You can also transfer audio to and from Studio One and Notion with the same command and different option. This is useful if you have a melody or chord progression and you want to write accompaniment parts in Notion.
• You can also send 44.1k 16 bit files from Studio One browser directly to Notion 6.
Rewire
• Previously available Studio One as the Master and Notion as the Slave you can link the two together to add Notion instrument parts.
• Previously available Studio One can record the Notion Instruments audio .
• New Studio One can access Notion Rewire MIDI channels as input to its own Instruments and record the input.
Drag and Drop
16 bit 44.1k audio form S1 browser to N6
Suggested Use cases: ( it depend on what you want to do and where you are more comfortable)
UCNET
Limitations: As of this release UCNET only support new documents( song/score). You can however have multiple documents open in each app and use copy/past to move the data to an existing song/score.
CRITICAL NOTE: Rewire and UCNet are not compatible. You can use one or the other not both.
It take a full restart of Notion to stop Rewire.
UCNet has been around since 3.0 in S1 but it new to N6. There are networking debug steps Here if you need to let your OS know about UCNET.
Step by Step procedure:
S1 to N6 UCNET procedure:
1) Start S1 and select track or song to export MIDI
2) Click Song/Send to Notion a prompt will come up to start Notion
3) Notion will start and prompt will change to option to send track ,song or audio mixdown
4) Select Notion on this computer, Send note data
5) Note data will be converted to notation in a track name that matches.
HINT: If the Instrument is 'Grand Piano' and 'Grand Presence' in the Artist's instruments Keyboards folder or Presence XT Piano or Grand Piano a Grand Staff will be created in N6.
Verify that you have Grand staff option set in the preferences.
If the Instrument is known to both S1 and N6 ( a VST like Kontakt or SampleTank 3. etc the patch will be shared
6) Save the Song in N6.
Rewire
Drag and Drop
UCNET
- If you are more comfortable using Notion to create/produce then S1>N6 notes/VSTs allows you to get S1 performances into Notion for notation purposes or all in one mixing in N6.
- If you are more comfortable in Studio One then N6 > S1 allows you to write via Notion and bring into S1 for Mixing,FX routing etc and Album producing.
- If you want to print sheet music for S1 Instrument tracks, then S1>N6 Note data works well.
- If you are more comfortable creating in Notion and only need a S1 vocal or rhythm section as an example, you can UCNet over the audio mixdown or stems to help you write the notation.
- If you are more comfortable mixing in Studio One then transferring N6 audio staffs to S1 tracks will work well.
- If you are Ok creating with both apps (in tandem) and are more comfortable in Notion, then N6>S1 N6 Rewire MIDI enables you to use the power of S1 Instruments/VSTs
- If you are Ok creating with both apps (in tandem) and are more comfortable in Studio One, then S1 Rewire MIDI allows you to use N6 Instruments as part of your S1 song.
