A search returns mixer-related crashes as late as 5.2.377. I'm getting them with version 5.2.381.
Am I the only one still getting these crashes, or has everybody resigned themselves to living with them? It is VERY annoying ... |
An auto bug report was sent on at least one instance today. I opened a ticket on it and provided the requested sys info file.
Maybe if enough of us do that Presonus will get enough info to isolate the cause. |
UPDATE:
Shortly after submitting the ticket on this, I switched Notion to Run As Administrator. I haven't had the crash again since making this change. I'm not 100% certain at this point, but it's looking good as a work-around. |
Wow.....Notion 6 still has that bug, huh? I don't have Notion 6 yet, but I was really hoping that bug would be "eradicated" by now. For me, as stated before, I have made it a habit to save, save, save, before hitting that "button. About 1 out of 3 times it'll crash. In the past I have lost a lot of work because of that bug.
Are you all on Windows ?
I just test it and I can play a full orchestra score featuring 4 VSL VE instances full of instruments and i have no problem to open and scroll and close de Mixer ...I did that several time and N6 runs perfectly ! I'm on Mac OSX ElCapitan.... ...old Mac pro 2009 ! |
Hello from Spain.
Please, excuse my poor English. I know is an old post, but I think I´ve found a solution. I had this problem since I updated Notion 4 to 6 (a few weeks ago). Every session in notion 6 that I opened the mixer was a risk of crash. The Presonus technical support has been really good in these days (thanks again, Brian), but the solution was circumstantial. Solution: I´ve just disabled the Windows sticky notes in the desktop. That´s all: no sticky notes in the desktop, no more problems with the mixer (for now). I started to use the sticky notes at the same time I updated to Notion 6. I´m not sure, but I´ve have to think it´s related to the issue. I hope this can be useful for someone. Best regards. M. Rosa |
Yes, Windows here. I still saw this after upgrading to Notion 6. Also on a new machine. I set Notion to run as admin and the problem went away again.
Where does one enable/disable Sticky Notes? |
