Bonjour,
One year ago I bought a Focusrite Scarlett 6i6, which I plugged in my desktop PC (Win7-Core i5). I could not use it with Notion (4 or 5) : every time I launched playback, Notion crashed after a few bars. Will Kent from Focusrite support gave me a link to a beta driver that solved the problem. Then one month ago for my birthday (a big one...) I was given a Surface Pro 3 tablet (Win8.1, Core i5). I bought a Scarlett 2i2 to match with it, and had Notion5 installed. Exactly the same problem : Notion crashes after a few bars playback. And exactly the same solution : a new beta driver link from Focusrite support. If anyone ever encounter the same issue, here is the link to this driver : http://beta.focusrite.com/file.php?id=1154 Hope it can help !
GD
PC Casawave Core [email protected] - 8Gb RAM W7-64-SP1 Home Premium Focusrite 6i6 interface - Studiologic SL990pro keyboard Reaper 6 https://hearthis.at/xnwdv7yv/ |
Thanks for posting!
I was having this happen, but only with Notion instruments. Other VSTi worked without a problem. This seems to have solved the issue, but now my Scarlett doesn't show up in MixControl. What's your experience? |
Hello Bill,
If you installed this driver : http://beta.focusrite.com/file.php?id=1154 Attention : This driver is only for Scarlett 2i2, which does not need MixControl (only 2in/2out). First time I had the issue it was with a 6i6, and here is the answer of Will Kent from Focusrite support : Hi Gerard, So I think you could try this one for your 18i20, but this link is one year old, and maybe could you get in touch with Will for a possible newer driver. Cordialement,
GD
Users browsing this forum: No registered users and 20 guests
