Hello all.
I've searched for a solution to this and came across the old forum which says, select your group of notes, press the "=" key and then select your time value from the menu but "=" didn't bring up a menu. Could anyone guide me ? I just want to change a group of 32's to 16's as I've entered them wrong. 🙄
Ta
Colin.
by michaelmyers1 on Sun Feb 21, 2021 2:52 pm
There's no menu or dialog involved. Select the notes, hit the equal key and then immediately hit the W, H, Q, E, S, or T key for the new time value desired for the notes selected.
macOS Big Sur 11.1 with small AOC monitor for additional display
JBL LSR310S subwoofer
Notion 6 + Studio One 5 Pro
http://www.tensivity.com
by colinmold on Sun Feb 21, 2021 4:06 pm
Thanks Michael.
There must be something I'm doing wrong. I'm in Melody Mode and selecting the notes by a left mouse button click and drawing across the group to highlight. I then press "=" followed by "s" but still nothing. I'll keep trying in case I find out what I'm doing wrong.
Changing existing notes values to a different value.PNG (3.86 KiB) Viewed 206 times
by michaelmyers1 on Sun Feb 21, 2021 6:39 pm
colinmold wroteThanks Michael.
Should work. Make sure you're in edit mode (the little conductor icon is gray, NOT blue).
by colinmold on Mon Feb 22, 2021 7:22 am
Mmmm, still doesn't do anything :roll: I'll investigate further and let you know if I get it working and what I was doing wrong. Must be doing something wrong.
by colinmold on Mon Feb 22, 2021 7:48 am
An update Michael. if I leave caps lock on, select the notes, press = followed by S to change the 32's to 16's. Nothing happens. If I turn caps lock off, select the notes, press = followed by Shift + S, that should equate to the same thing but my mouse pointer changes to a slur. Is it related to the menu I have active or something ? I have a note value sub menu active
PS I have now located section 10.5 of the user guide which says exactly what you've told me.
by michaelmyers1 on Mon Feb 22, 2021 7:35 pm
Curious. On my system, I get the same behavior regardless of caps lock or not. I hit =s and it changes selected notes to sixteenth. If i do = shift s, i get the slur. I use that keyboard shortcut all the time, shift s gives me a slur.
Sounds to me like an oddity with your system or maybe your keyboard settings. Might want to submit a ticket to Notion support.
by Surf.Whammy on Tue Feb 23, 2021 2:30 am
colinmold wroteAn update Michael. if I leave caps lock on, select the notes, press = followed by S to change the 32's to 16's. Nothing happens. If I turn caps lock off, select the notes, press = followed by Shift + S, that should equate to the same thing but my mouse pointer changes to a slur. Is it related to the menu I have active or something ? I have a note value sub menu active.
As best as I can determine, you are doing this on a Windows machine? :)
I searched your posts and found one where you referred to "ctrl-D (PC)", which is why I am guessing you are doing this on a Windows machine, which is fine . . .
michaelmyers1 is on the Mac-like me-so there are differences, where for example the Mac has a "control" key but no "ctrl" key, and "ctrl" on a Windows machine maps to the "command" key on a Mac . . .
This could be due to the type of mouse, trackpad, Watcom drawing tablet, or other mouse-like device you are using, or it could be something else . . .
Some of the shortcut and hotkey combinations are different on Windows machines . . .
Generally, everything on the Mac is the same for everyone--with the exception of the language one selects with respect to the keyboard, where for example German keyboards have a different layout and characters from English keyboards, mostly due to German having things like umlauts and characters that are not on an English keyboard . . .
[NOTE: On German and other international keyboards, note duration values are numbers rather than characters like on an English keyboard (actually an American keyboard, but so what) . . . ]
Whether it matters is another topic; but I think it's a general rule that you can do everything NOTION does regardless of whether your computer is a Mac or a Windows machine . . . :+1
One thing I noticed, which on the Mac is a bit non-standard, is working with "caps lock" ON . . .
I nearly never use the "caps lock" key on the Mac . . .
The Surf Whammys
by colinmold on Tue Feb 23, 2021 5:48 am
Thanks for your replies folks :+1 Yes I can confirm I'm on a Windows 10 machine. I wish these days that I was using a Mac :roll: I'm fed up with MS Windows but that's another story. Can't afford to change at the moment.
Well, based on your responses, I'll have a play around with it this evening and see if I can solve the problem. :+1
ttfn
by colinmold on Tue Feb 23, 2021 3:23 pm
And the answer is, the keyboad mapping of US vs UK although having worked with Terminal Emulation software before I thought "=" + "s" would have been the same with a US keyboard as it is with a Uk keyboard. Don't really get that. Anyway it's all clear in the short cuts document below. Mine keys are 5-0
I shall keep the shortcuts .pdf open in future as it'll help.
by michaelmyers1 on Tue Feb 23, 2021 7:31 pm
I had thought at one point that it might be keyboard mapping.
At least you got it figured out!
by colinmold on Wed Feb 24, 2021 3:54 am
Yep all good Michael, although having changed my 32s to 16s it joined that group with a beam to the following group of 32's I had yet to change. When I tried to remove that beam, the program crashed but that's another topic I think. At least we got to the bottom of the main issue even if I'm still no better off :-). I'll probably just start again. Cheers. :thumbup:
