Hi all,
I'm probably doing something obviously incorrect here but I need to copy a 16 bar passage of notes and paste them elsewhere on the score. However, when I start to highlight and drag across the bars, the highlighting just stops at the right edge of the window and won't go any further. My assumption was that it would keep going until I released the mouse button,but no. I tried viewing in continuous mode and shrinking the score but that just does the same thing. Any ideas ? Thanks Colin. |
With your cursor hovering over the first measure of the passage, double click to select the first measure, then move to the last measure you want to select and use shift+double click in that. Notion will select all the measures in between. It takes a little getting used to but once you figure it out it becomes second nature.
Last edited by michaelmyers1 on Thu Nov 26, 2020 11:46 am, edited 1 time in total.
macOS Big Sur 11.1 with small AOC monitor for additional display 2 - 500 gb + 1 tb external SSD for sample libraries M Audio AirHub audio interface Nektar Panorama P1 control surface Nektar Impact 49-key MIDI keyboard Focal CMS40 near-field monitors JBL LSR310S subwoofer Notion 6 + Studio One 5 Pro http://www.tensivity.com |
