While making selections from the symbols palette Notion defaults to a white ( the score) and grey background on my PC. This almost makes my pointer and some symbols disappear when I drag them across the screen.
Is there a way to highlight the selections until they are landed at their correct places?
I literally lost my pointer a few times against the white score background.
by Surf.Whammy on Fri Jul 31, 2020 1:46 pm
Tmothy wroteWhile making selections from the symbols palette Notion defaults to a white ( the score) and grey background on my PC. This almost makes my pointer and some symbols disappear when I drag them across the screen.
Look in NOTION Preferences for "Theme" . . . :)
NOTION has three themes, (a) default, (b) Dark, and (c) Parchment . . .
Try the Parchment theme and see if it helps . . .
Another possibility is to experiment with the various Accessibility features of your selected operating system (macOS or Windows) . . .
Both operating systems have Accessibility features, which on the Mac include options based on specific vision conditions . . .
On the Mac, the Accessibility options are found in System Preferences (right-click on the Apple icon at the top-left corner of the screen, and a menu appears where you can select and start System Preferences) . . .
Here in the sound isolation studio, I am using an Apple 30" Cinema HD Display from 2004 that I found on eBay a few months ago for $250 plus shipping, and sometimes it's nearly impossible to see the mouse pointer . . .
In System Preferences in the Accessibility section, there is a set of options for the Mouse, and one of them makes the mouse pointer big when you shake the mouse . . .
I use this accessibility option for the mouse, and when I can't see the mouse pointer, I "shake" the mouse and the mouse pointer gets big for a second or so--long enough to find it . . .
It's in the Display section and is the option to "Shake mouse pointer to locate" . . .
There also are various ways to make the screen easier to see, but some of the options are for more extreme vision difficulties . . .
I also use a mouse pointer utility application, but mostly for doing YouTube videos . . .
There is a "Zoom It" utility that turns the mouse pointer into a magnifying glass; and there is one called "PinPoint" that creates an outline around the mouse pointer, as shown in this YouTube video . . .
These are paid products, and you can get them from the Apple App Store or online via searching, since they probably have websites where you can download after purchasing . . .
As I recall, they are about $25 to $50, and I find them helpful for various activities . . .
It will work similarly in the Windows universe . . .
There are hotkeys that toggle the mouse pointer enhancements (ON or OFF) . . .
Both of them allow you to define your own hotkeys or shortcuts for this purpose . . .
PinPoint has various options, and I like option to have a red circle around the mouse pointer . . .
There are other mouse pointer utility applications for the Mac, and there are similar mouse pointer utilities in the Windows universe . . .
One or more of these options, themes, and so forth should be helpful; so experiment with them to get a sense of what they do . . .
As a word of caution, if you are experimenting with the option to make portions of the display very large, be certain to find how to turn stuff OFF . . .
I was experimenting with making the Desktop vastly larger, and it go so large that a period or a comma looked the size of a baseball or even a basketball; but since I forgot how to turn it OFF, it took quite a while to move the mouse pointer to the OFF button--perhaps 15 minutes or longer, since in the extreme setting, stuff gets nearly absurdly big . . .
It zooms-in to the level that a single word is the size of the entire display--perhaps even larger . . .
SUMMARY
Try the Parchment theme for NOTION, and if you are on the Mac, then set the shake option to make it easier to find the mouse pointer . . . .
Try some of the other Accessibility options . . .
P. S. You can make staves and notes larger via zooming in NOTION, which is another thing I do . . .
NOTION does not remember zoom settings; so you need to zoom to the desired setting each time you open a NOTION score, but there are hotkeys for doing this; and it's as easy as doing cut, copy, and paste actions (press two keys, and you can zoom-in or zoom-out) . . .
On the Mac, in the Mouse section of System Preferences there is an option to use the mouse to zoom-in and to zoom-out via tapping on the mouse . . .
For reference, I did software engineering in Windows for two decades, starting in early-1987, and on the Mac starting about 20 years ago; so I know about accessibility and usability options . . .
Generally there are three classes of these things (system level, application level, and specific accessibility level), which is fabulous . . .
Fabulous! :+1
The Surf Whammys
by Tmothy on Tue Aug 04, 2020 12:01 pm
Thank you Surf Whammy,
Many useful suggestions and most helpful. :+1
I'll keep it short. Hurricane came through here. Computer went down three times. Not sure how long I'll have it this time.
by Surf.Whammy on Tue Aug 04, 2020 8:22 pm
Tmothy wroteThank you Surf Whammy,
If you're worried about lightning strikes, then get an ISOBAR Surge Protector . . . :)
When the electric service goes out in a gracious way, no harm done--other than being offline and after a while not having ice--but when there is a nearby lightning strike, it's a different matter . . . .
I use Tripp-Lite ISOBAR Surge Protectors here in the sound isolation studio, and they are excellent . . .
They have heavy-duty components, and they are designed to fail catastrophically when there is a lightning strike . . .
They take the hit instead of your computer and audio equipment; and they have $50,000 insurance in case they don't protect your computer and audio equipment, which is a clue that they rarely do not protect computers and audio equipment . . .
They also have backup power and line-conditioner units . . .
There is detailed information at the Tripp-Lite website (see link below) . . .
Tripp-Lite
P. S. After being in the path of a hurricane more than a few times, where electric service was out for several weeks, the single most important thing to have is a gasoline, diesel, or natural gas powered electric generator--which you always keep outside the house . . .
[NOTE: The eye of Hurricane Rita went directly over the house. 100 to 150 mph winds for 12 hours before and after, but about 1 hour of surreal calm. Electric power was out for several weeks, but I had plenty of gasoline and a very nice electric generator, so there was ice . . . :+1 ]
I drilled a hole in the wall to run the electric extension cord from the electric generator to the inside of the house, which worked nicely and avoided carbon monoxide poisoning . . .
Why is this important?
One word: ice . . .
Most folks never appreciate having ice until there is no ice available anywhere . . .
Food, water, medicine, and all that stuff is important, but when it's summer and hot, ice is like gold . . .
With an electric generator, you can run the refrigerator and make your own ice . . .
If it has enough power, you also can run at least one window air-conditioner and the computers in your music studio, which is fabulous . . .
Fabulous! :)
The Surf Whammys
by Tmothy on Wed Aug 05, 2020 10:00 am
Thanks for all of that information Surf Whammy. Yes I definitely need to get more protection for my gear. In my studio I have both power surge and RF filtration. I forget the make. It was fairly expensive for a power strip. I don't have battery backup though.
Fortunately the power failures were at another computer and location totally not anywhere near my studio.
At home I have a 5500 watt generator. Largest issue in keeping it functional is rodents occasionally in my storage shed and keeping fresh fuel in it. I have fuel stabilizer in the tank which helps. I have only needed it maybe two or three times for short term use in the last 10 years. I use the back feed method into a 30 amp breaker. The 5500 watts is enough to power my well pump, a few lights and my fridge. In an emergency it could also power my propane furnace. My hot water is a large point of use instant water heater. Too much current so it's a COLD shower. I installed gas appliances last year instead of electric ones. I won't loose the ability to cook. Alternately I could heat water for a bath that way as well. I have a few stand alone gas heating appliances just in case it happens to be winter and i loose power. We don't often loose power here. Occasionally it happens though. In that case I'm probably going to my laptop for any audio work.
I ran new underground electric service to my house last year. Had a guy digging a hole to the patch point. I said to him " Hey you're getting very close to the electric line". Right as I said it POW. He hit one of the three legs into the house. That was a lot of fun.
