Audiobox 1818VSL has 47 volts ac on chassis
Posted: Fri Dec 25, 2020 9:07 pm
While trying to eliminate a ground loop I installed Humfrees ground isolation tabs between my Presonus Audiobox 1818VSL interface and my equipment rack. I then attempted to check the resistance between the chassis of the interface and the rack with my digital voltmeter but it automatically detected 47 volts AC between the rack and the interface. In order to simplify things as much as possible for testing, I removed the Audiobox 1818VSL from the rack and placed it on my desk, which is wood. Then I made a cable that plugs into an AC outlet in the wall with the hot and neutral taped off and only the ground (green) wire stripped. I then connected my digital voltmeter between that ground wire and the barrel of the plug which connects to the 19volt DC input on the Audiobox 1818VSL. I see 47 volts AC whether I measure from the ground wire to the outside of the DC power barrel or the hole in the middle of the barrel. While the plug that connects to the AC outlet in the wall is polarized, the other end that connects to the power brick in the middle of the power cord for the 1818VSL is not so I reversed that and I still measure 47 volts AC at those two points. I don't think it should be normal. I also do measure 18.9 volts DC in the hole of the barrel, which is expected. If I connect that to the power jack on the Audiobox 1818VSL, I measure the same 47 volts AC on the chassis of the Audiobox 1818VSL with respect to the 110V AC outlet ground wire.
Can anyone provide me with help regarding this mystery?
Thanks,
Don
Thanks,
Don
