audiobox 1818 vsl troubles!
Posted: Mon Oct 05, 2020 6:43 am
by edmilsoncardoso
I know that Presonus has discontinued the VSL program because it is not working well with Macs! reported that the 1818vsl audiobox would work well without the program! I would like to know how to configure the outputs and the clock signal without the program on windows!
Re: audiobox 1818 vsl troubles!
Posted: Wed Oct 21, 2020 11:42 am
by cristofe
Windows pc's are NOT Macs. You can't do it. You need either the latest version of Universal Control or version 1.3 if you want full VSL functionality. Both work fine.
That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW, make and model of your audio interface etc....we often can't recommend a "simple fix"
Posted: Wed Jan 20, 2021 3:21 am
by matthewlittle1
Cristofe, I have the AudioBox 1818VSL interface, running Studio One 4 Pro, on a 2019 iMac with macOS Catalina 10.15.7, 3.7 GHz 6-Core Intel Core i5 processor, and every time I try to open a project and play it back, nothing happens, no sounds, no movement of the placement bar, nothing. I know the support for the 1818VSL has been long discontinued, but is there anyway to fix this? Or any drivers that are compatible with my macOS?
Posted: Wed Jan 20, 2021 6:47 pm
by matthewlittle1
Posted: Thu Jan 21, 2021 1:04 pm
by cristofe
Sorry, I do not use ANY Apple products. But many here do. Perhaps a Mac user will chime in on this issue.
