I have successfully mapped two analog channels (Mic 1 and Instrument 2; inputs 1 & 2) to Jamkazam. When I run a standalone virtual instrument like Addictive Keys, my USB MIDI keyboard controller (Nektar Panorama P6) shows up in the AudioBox mixer as a stereo feed on the DAW 1 & DAW 2 digital channels. That's great, but I can't figure out how to get 3rd party apps to see those DAW digital channels.
Can I map them as inputs the way I can the analog inputs? Thanks in advance. I'm running 64-bit Win7 Studio One 2 Professional, as well, but don't want that to be part of the solution as it would add significant latency.
Intel i9, 32 GB RAM, 7 TB SSD Win10 Pro 64-bit PreSonus Studio 1810c
Studio One 5 Pro Notion 6 Melodyne 5 Studio Acoustica Pro 7 Guitar Pro 7 PreSonus FaderPort M-Audio Keystation 61 MK3 M-Audio BX8 D2 Beyerdynamic DT 880 Pro NI K9U IKM MODO Bass, MODO Drum AAS VS, GS, VA, EP, CP, OD Toontrack SD3, EZkeys, EZbass |
If your audio interface is ASIO (which is best for latency!), Jamkazam will not be able to see those virtual instruments running on your computer. But I learned something this week - you can have two ASIO interfaces in Windows, as long as they don't use the same program. I have a second USB ASIO interface - I connect that and use that with virtual instruments (I use Cantabile as a VST Host, but you could even use Studio One). I cable the outputs from the second interface into my main interface inputs....Now I can hear and use those virtual instruments in JamKazam!
