Hello,
I have been using the Audiobox 1818 VSL for recording guitars/drums/vocals/etc. for several years now. I recently purchased a Behringer Deepmind12 to use as an external synthesizer/keyboard with my setup.
Unfortunately, I am new to MIDI technology and while I am able to generate note values/velocities within a Studio One song, not sound accompanies the notes. I am sure there is a simple solution to this problem, but I am unable to see it. I know MIDI cables only transmit computer data between hardware, not sounds, so I am wondering what else I need to connect to have a functional MIDI track.
Note that I am able to use the DeepMind 12 as a stereo instrument with 1/4" cables, however that kind of defeats the point of the MIDI connection.
I checked the firmware of both the Audiobox and The Deepmind12 and they are up to date
Gear used:
AudioBox 1818 VSL, version 4.1.2.50657
Behringer Deepmind 12, firmware version 1.1.2
2 MIDI cables (DM12 in > AudioBox out, AudioBox in > DM12 out)
I can provide any additional information as requested.
Kind Regards
by cristofe on Wed Jan 23, 2019 1:56 pm
There are TONS of videos on You Tube that will show you what you need to do.
There's this thing called Google.....LOL
https://www.google.com/search?q=how+to+set+up+a+presonus+1818vsl+with+a+hardware+midi+synth&oq=how+to+set+up+a+presonus+1818vsl+with+a+hardware+midi+synth&aqs=chrome..69i57.29771j0j7&sourceid=chrome&ie=UTF-8
by stuartdeland on Wed Jan 23, 2019 6:12 pm
Thanks for the response, most of the videos on youtube and google explain how to set up a MIDI keyboard....without the synthesizer part of it. Yep, read the manual for both pieces of hardware, I'll figure it out I'm sure.
