SPDIF & ADAT Inputs?
Posted: Sat Dec 15, 2018 6:36 pm
by georgelea
If I want to use the SPDIF and/or the ADAT INputs isn't this (Note Attached jpeg) the correct way to configure it? If not, what is? Actually, what is the signal flow if I have my external keyboard controller analog INputs plugged into Ch.s 5&6?
Thanks,
George
Re: SPDIF & ADAT Inputs?
Posted: Sat Dec 15, 2018 7:08 pm
by georgelea
Attempt to answer my own question about signal path. My assumption was that I could connect from the OUTput of either SPDIF or ADAT from my keybd workstation INTO the INput of those ports on the 1818VSL, then the signal would be internally routed to the USB port keeping it in the digital domain? Isn't that logical?
