If I want to use the SPDIF and/or the ADAT INputs isn't this (Note Attached jpeg) the correct way to configure it? If not, what is? Actually, what is the signal flow if I have my external keyboard controller analog INputs plugged into Ch.s 5&6?
Thanks,
George
Alesis Fusion 8HD kybd, PreSonus 1818VSL, PreSonus FaderPort8, JBL LSR 308 monitors. ASUS M5A97 EVO Mobo, 16Gig RAM, AMD FX-6200 CPU 3.8 Mhz, AMD Radeon HD 6670 Display. Win10 Pro 64Bit
by georgelea on Sat Dec 15, 2018 7:08 pm
Attempt to answer my own question about signal path. My assumption was that I could connect from the OUTput of either SPDIF or ADAT from my keybd workstation INTO the INput of those ports on the 1818VSL, then the signal would be internally routed to the USB port keeping it in the digital domain? Isn't that logical?
