I have a 44VSL and Studio One 3 Pro (Windows 8.1). I am using the Universal Control as a driver for the AudioBox. I user the line outs to send signals from the AudioBox to other audio gear (mostly cameras). The AudioBox inputs and outputs are controlled within Studio One with the menu Audio I/O Setup under Song Setup. The attached photo shows the initial values of the inputs and outputs. Through trial and error I am slowly discovering how to control the content of each of the 4 line outs but I am struggling to understand the exact relationship between the 4 line outs and 4 inputs when adding mono and stereo signals in Audio I/O Setup. Is there any documentation for this that gives an explanation of all the controls within Audio I/O Setup?
by cristofe on Sat Aug 25, 2018 1:30 pm
There are literally hundreds of videos on this subject on YouTube. A quick Google search will turn up everything you could possibly need to know:
https://www.google.com/search?q=setting+44vsl+with+studio+one&source=lnms&tbm=vid&sa=X&ved=0ahUKEwipgaL094jdAhWFVt8KHXaBDw8Q_AUICygC&biw=1280&bih=614
by briancassidy on Sun Aug 26, 2018 12:25 pm
Thanks for the response. I have added a signature and I can confirm that I have read the manuals (AudioBox User Guide and Studio One Guide). I have also waded through numerous YouTube videos but it's hard to find just the right info. Essentially I am trying to place all 4 AudioBox inputs on a mono bus and route that simultaneously to Line Outs 1&2. Maybe I have that already with the default I/O configuration but I am not sure. The Audio I/O Setup / Output tab shows the Main bus with the left channel going to Line Out #1 and the right channel going to Line Out #2 which is not really what I want. Maybe the 44VSL can't do what I want to do. I wonder if the Studio One forum is a better place for this question.
Computer: ThinkPad T450s W8.1 - Audio Interface: AudioBox 44VSL - Audio Software: Studio One Pro 3
by cristofe on Sat Sep 01, 2018 10:48 am
Maybe so as it is in Studio One that you set up the 44VSL's routing options.
