I have an old 2-channel Firebox with a fried AC adapter. I got a VSL1818 back in January and considered getting a new adapter for the Firebox (which i will do just since the preamp is still fine). Is it possible to daisy chain the Firebox and VSL1818 through the spdif connectors? As I understand, spdif is sort of the predated version of an ADAT connection. I don't have the original midi/spdif connector so I'll have to order one. Just wondering if it's worth putting money into, or if I should look into other options for adding channels.
-The Firebox drivers do function on my OS |
Ok, let's try this again.....the answer is NO. NEITHER of these devices is a standalone PREAMP.
In order for either of them to function they must be connected to pc and you can't connect a USB and Firewire INTERACE to one pc at one time. As I CLEARLY stated in my last response, if you want to add channels to your 1818 you MUST use a STANDALONE preamp/ADDA converter such as the Digimax or Behringer ADA8000. Using one of these with ADAT inputs will get you eight more channels. In order to add channels via the SPDIF ins you still need to use a STANDALONE digital preamp with SPDIF outs such as the ART DPSII. https://www.sweetwater.com/store/detail/DPSII--art-dps-ii |
