Hi there:)
Following Problem: (Driver 1.3 and VSL, Sonar and S1) Signal Output from the DAW to Audiobox Main Out L and R! Signal Input in VSL DAW 1 & DAW 2 Faders to 0 , Aux 7 Out to Headphones Signal inVSL in Headphones and Main Out ================================== Signal in Headphone on the front of the Audiobox Signal from Output 1/2 at the back of the Audiobox ---> No Signal Out from the Main Outputs at the back of the Audiobox Question: Why?? I've tried Balanced and unbalanced cables, sticked the headphone in the outputs, no signal from the Main Outs:( Is there a switch which I cannot see or recognize?? Thanks a lot:) Heinz. |
HI:)
Now that I tried it again today it works. But I have no idea why:( It's all the same, same cables, same settings, knobs on the same values, even the same projects in S1 and Sonar, I can't help, but it works! Trying again tomorrow, it's unbelievable.... The only thing I have done is testing all Inputs with a mic, nothing else. This means I switched Phantom Power too. Greetz, Heinz. |
1&2 share headphone 7&8. Line Outputs. The AudioBox 1818VSL has eight line outputs to route
to external devices, such as headphone amps and DJ mixers. Outputs 1 and 2 share their playback streams with the Main Outs. Outputs 7 and 8 share their playback streams with the headphone output. Maybe help? Skip
Skip
