42 postsPage 2 of 3
1, 2, 3
I have an ADA8000 will that work the same as the Digimax D8?
by sharonzaz on Wed Jun 17, 2015 10:59 pm
yes
http://www.sheron.co.za
https://www.youtube.com/user/sheronmusician/videos
https://soundcloud.com/sheron-imj-band/tracks
MacPro i7 12GB Ram SL 10.6.8
MBP MD101 i5 - 2.5 OS X 10.10.3
RME Multiface
Yamaha 01V96
1818VSL (Sold and gone forever)
Yamaha MSP10+SW10
Mackie DL32R
Focusrite VoiceMasterPro
Logic Pro 9
Logic Pro X
by cristofe on Thu Jun 18, 2015 10:54 am
Technically yes, BUT the ADA800's pres are not quite as good as the 1818VSL's or D8's. Several guys using this combo have said when recording 16 simultaneous tracks with this rig they'll use the ADA's pres for less critical tracks like drums.
by alrubin3 on Mon Jun 22, 2015 11:09 pm
thank you for the helpful insight.
by cristofe on Tue Jun 23, 2015 11:32 am
:mrgreen: :mrgreen: :mrgreen:
by Danalee on Thu Oct 01, 2015 9:05 am
if i bought an 1818vsl, and a digimax d8, would i have an option to later use a 2nd digimax d8 to give me 24 channels?
THE MUSIC ROOM
Record - Mix - Master
Audio Production
PRESONUS
Studio One 3, Fader Port, 16.4.2, 24.4.2, RM32
Eris 5 & Sceptre 6 Monitors
Windows 7 Pro, I7 quad core, 16 gigs ram
(http://www.customwiring.net/themusicroom)
by matthewgorman on Thu Oct 01, 2015 9:43 am
Danalee wroteif i bought an 1818vsl, and a digimax d8, would i have an option to later use a 2nd digimax d8 to give me 24 channels?
No. 18 channels max. You would want to look at the Studio 192, which can take up to 2 8 channel adat pres, and an addiotiuonal 2 channels spdif for 26 total. Also has up to 32 outputs, speaker management, talkback, and fat channel processing on the 8 analog ins of the 192.
All indications are that it hits the street soon.
Matt
S1Pro V4
by Danalee on Thu Oct 01, 2015 9:47 am
Gotcha Thanks
THE MUSIC ROOM
Audio Production
PRESONUS
by matthewgorman on Thu Oct 01, 2015 10:06 am
Another benefit is remote control of the mic pres through S1 V3.
Matt
S1Pro V4
by sbeblis on Wed Dec 30, 2015 7:51 am
Hello,
How would I add a blue tube dp as an additional input ? If this is possible can 2 blue tube dp units be added as 2 additional channels?
Thank you
by matthewgorman on Wed Dec 30, 2015 8:24 am
sbeblis wroteHello,
Thank you
Sorry, but no. There are no separate line inputs for a BlueTube. Expansion of inputs for the 1818 can only happen via spdif (2 ins) or adat (8 ins).
Matt
S1Pro V4
by dnoise on Fri May 27, 2016 7:39 am
I used 2, indeed one as ADAT to the other and it worked fine. The mixer nicely shows the additonal ADAT channels from the second box, performance no problem.
The one issue which makes it a hassle is indeed that you have to connect each box to a separate PC. If you connect them to the same PC the sampling goes wild and you get funny digital noise.
My guess is this has to do with the design of the drivers on windows and actually could be remediated if there would be a dummy driver for the box that is in adat mode.
If there is anyone out there from PreSonus who could help? Because using 2 PCs really does not make this practical.
The end model could be then to have 2 boxes on one PC, use Teamviewer to share the Mixer to an Android Tablet (as there is only IOS tablet version) and there we go, we have a 18 channel mixer with remote control.
by GARPOD on Wed Jun 22, 2016 3:26 pm
hello anyone here
by matthewgorman on Thu Jun 23, 2016 8:49 am
What's your question?
Matt
S1Pro V4
by cristofe on Thu Jun 23, 2016 10:38 am
GARPOD wrotehello anyone here
Nope.
If you want "the answer" my son you must first ask a question. That being said
we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW etc....we often can't recommend a "simple fix"
by mattkelly-terribile on Mon Jun 27, 2016 7:08 pm
Hi everyone,
I'm having some trouble getting ADAT and SPDIF to work. I just bought a ART tube opto 8 to add 8 channels. Hooked it up via optical and worked imidiately. 16 channels no problem. I added and ART digital MPA to use SPDIF, and it isn't showing up. In studio 3, it shows the input is active, but no sound. Any ideas?
by cristofe on Wed Jun 29, 2016 2:20 pm
The MPA has switch selectable digital outs......have you made sure the switch is set to SPDIF and not ADAT out?
by joehernandez1 on Mon Apr 10, 2017 9:29 am
new to forum, hello, im about to purchase a digimax D8 to use with my 1818 vsl, has anyone done this and is there any foreseeable problems I may encounter, thank you in advance...joe
by cristofe on Mon Apr 10, 2017 11:18 pm
No worries, the D8 and 1818 work great together! :+1
by joehernandez1 on Wed Apr 12, 2017 2:11 pm
hello, I just purchased a Digimax D8 to piggy back with a 1818 vsl, can someone tell me exactly what wires I would need to do this, thank you in advance.
42 postsPage 2 of 3
1, 2, 3
