I recently installed Universal Control 2.0.2.42749 to my new laptop so I could use it with my AudioBox 22VSL, as an audio interface to my Presonus RM80s. Laptop is running updated Windows 10 Home.
I've noticed that every time audio begins to play, the speakers click twice, and then whatever sound was about to play. Ex: When Thunderbird receives new email, it plays a little notification "ding" to let me know. Before that ding plays, there's these two little pops and then the sound. I don't have any trouble when music is playing. It's not like a bandwidth issue where audio buffers are running out (after all, I'm only using a 2 channel device, and not doing anything intense; just using it as a sound card; no DAW nor recording happening). It's almost like a power-up sequence, or some kind of initialization. But, the power LED never goes out, so it doesn't seem like that's an issue. It's plugged into a powered USB2 hub because my laptop has only a single USB Type A jack (the others are USB Type C) and I have the 22VSL and my keyboard plugged into the hub. Nothing really spectacular. Any thoughts? -- Mitch |
Hi everyone,
WARNING: READ THE EDITS FIRST Maybe this will fix it for some of you, it worked for me. (No more popping twice before playback, crackles, etc.) Just so you know, I'm on Windows 10 64-bits. 1. Plug your Audiobox audio interface in your computer's USB port 2. Launch and open the driver window if you have it installed (Universal Control 2.2 OR Audiobox22VSL v1.3, I have the latter but I think it will work either way, don't install them both though) 3. Set your prefered sample rate in the driver settings (e.g 44100,48000,etc..) 4. Right-click on the volume/speaker icon in your Windows 10 system tray 5. Select Playback Device 6. Right-click on your Audiobox (the one inside the Playback Device parameters) > Properties > Advanced 7. Choose the same sample rate as the one in your Audiobox driver (I don't think bit depth matters here) A good way to know if this works is to right click in your Audiobox inside Playback Device and launch a sound test 2 or 3 times straight. If you don't hear it popping before playing, you should be on the right track. You may hear it popping everytime you re-boot right before the Windows login screen but that's totally normal. If it doesn't work, try to uninstall/reinstall everything using this guide: http://support.presonus.com/hc/en-us/articles/210044673-How-do-I-uninstall-and-reinstall-my-AudioBox-drivers-in-Windows-8-or-Windows-10- Let me know if it worked for you! Best regards EDIT: It does not work anymore, it pops twice each time I switch from an application to another, when I close a program and reopen it, like chrome, windows media player, foobar2000, you name it. If I don't use the same sample rate for playback and record in the windows playback device settings, my microphone won't work at all (no green bars when i tap/speak on it). It will work again as soon as I put the same sample rate as the playback. I've tried EVERYTHING. I don't get it. It didn't do that before! Sometimes some clicks and pops but I didn't need to change the playback device settings. I have an Audiobox 22VSL. It's driving me crazy. I can't find the problem. Reinstalled Windows 30 times, tried each combination of drivers, USB ports, all the Windows settings.. I don't get it. Please if someone knows why tell me![/b] EDIT 2: Ok I think it didn't work anymore because I went from the Audiobox22VSL 1.3 driver to the Universal Control. Just went back to the 22VSL. Before that, I tested a Focusrite Scarlett 2i4 and it worked perfectly. I noticed that in the Playback Device Windows Settings with the Scarlett plugged in, the Playback and Record sample rates were automatically synced and the bit depth too. Windows settings were updated when I changed them from the Focusrite driver settings. Anyway, uninstalled Universal Control, went back to the Audiobox22VSL 1.3 driver, and now I don't have pops anymore AT ALL. Just like with the Focusrite. BUT I have to sync the sample rates in the Windows settings MANUALLY, otherwise it will cause problems. In short, make sure your playback and input are synced at the same bit depth & sample rate in the windows sound settings AND that the sample rate in the Audiobox22VSL driver is the same as those. Phew.. I don't know if it will last, but for now it's working. I'll keep you up to date even though I'm talking to myself like a mad man here and nobody even cares but maybe it will help someone |
Hi All
My AudioBox 44vsl is doing the same thing since i upgraded from 1.3 to 2.2 and it's really hard to revert to 1.3 again. So i upgraded to 2.3 thats just come out still the same. Anyone else having this issue still or did we get a fix that SUPPORT doesn't know about yet? It's making using the interface unbearable now. |
So tech support basically blamed my pc for not being up to date and causing driver conflicts.
After a lot of work on my side when i couldn't revert back to the 1.3 drivers as it said i had no device plugged in i manually removed every trace of the drivers from the registry and the PC. I used Auslogics Registry cleaner as you can search really easily for specific items. What i did note was that when i had the 2.3v drivers in they still said 2.21 dated Feb16. I then reinstalled 1.3 and it installed all fine again. I didn't really want to install the 2.3 drivers again as i was convinced they wouldn't work but as i wanted to get to the bottom of it i took the plunge and installed again. Guess what...........no more bit rate clicking!!! Looking at the driver version now it is still dated Feb16 but now version 3.34.0.0 I hope this helps you guys fix your issues. |
I can confirm the same double pop noise at the beginning of any playback using the latest driver Universal Control v3.1.2.54970
Uninstalling and going back to PreSonus AudioBox Installer v1.3.5653 fixed the problem right away. So they definitely messed up something in the latest driver... OS: Windows 10 Pro 1909 64bit |
Bermhed wroteI can't figure out where the old drivers can be downloaded, can anyone explain where to find them? https://www.presonus.com/products/Audio ... /downloads
Scroll to the bottom |
Best answer: viewtopic.php?p=148422#p148422
Thank you. |
