Whatever sampling rate I select in the control panel it reverts to 48kHz.
I can't change to 16 bit recording. I want to use 44.1kHz and 16-bit. Cheers, Mats N |
You need to select the sampling rate in BOTH Studio One AND the AB's control panel.
That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW etc....we often can't recommend a "simple fix" If you have not already done so please READ THE MANUAL!
Great! Glad to hear you got it sorted out!
