I left it unused for a couple months and yesterday when I was gonna go back to using it I couldn't because it was stuck with this "blinking red light" pattern.
I then opened the unit and I saw a fair amount of dust which I removed using a dry brush. It apparently worked. The unit went back to its normal functions.
But today when I was using it as a playback device hours later it went back to the error. Red light blinking accompanied with a click or pulse on the headphones (in sync with the blinking).
What's this pattern related to?
by rafaellima8 on Tue Apr 26, 2022 3:51 am
The blinking wasn't a warning signing a particular error but the power supply which wasn't sending a continuous current but instead having hiccups.
I replaced it and the unit is working fine now. :)
by gallant095 on Mon Jan 08, 2024 9:39 am
Hi @rafaellima8, I have the exact same problem right now with my unit.
You replace the power supply and that's it ? where did you buy that power supply ?
thank you !
by rafaellima8 on Tue Jan 09, 2024 11:03 am
I just had one laying around with the same specs. Same voltage, polarity and plug.
