I know that Presonus has discontinued the VSL program because it is not working well with Macs! reported that the 1818vsl audiobox would work well without the program! I would like to know how to configure the outputs and the clock signal without the program on windows!
by cristofe on Wed Oct 21, 2020 11:42 am
Windows pc's are NOT Macs. You can't do it. You need either the latest version of Universal Control or version 1.3 if you want full VSL functionality. Both work fine.
That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW, make and model of your audio interface etc....we often can't recommend a "simple fix"
