Why i cant use my presonus audio box 22 vsl any more since Oct 2018 till now.
I try to re-install updated driver many many times but waste time to do that anyway. Many comments i fiund in the internet there are Many of your customers facing this like me but no any one from presonus support team can help. Just advice very poor answers that every one can think that easily and do that themself . My English very bad but you know what i am writing sure!!
I amvery angry now with this. $#@&$_=/&$&%$€^$&¥$^¥/=;#@
:rtfm: :rtfm:
by cristofe on Wed Feb 06, 2019 12:33 pm
First of all my VSL interfaces work just fine here. It could be any number of things. Have you optimized your pc for audio production? Have you disabled wi-fi? Are you plugged into a USB2 or USB3 port? Audiobox interfaces are port specific....you must plug them into the same port you installed them to!
by adriantysoe on Tue Jun 11, 2019 11:14 pm
If your using a VSL interface on an up to date Win10 PC. The only drivers that will work are the:
PreSonus_AudioBox_Installer_v1_3_5653.exe
I've been using them for several months since I bout a 44VSL at a bargain price. Everything works fine, I use it for recording guitar, podcasts, video game audio. Direct input from my amp and realtime note recognition in Rocksmith and Yousician lol. I can use it to send and return for effect in front and in the loop of my amp. It's pretty cool.
by cristofe on Tue Jun 18, 2019 4:26 pm
Sorry, but that is not true. Newer drivers work just fine. You simply do not have access to the VSL software. And THAT is because Microsoft made changes to their OS's that broke VSL functionality.
However VSL interfaces can still be used as regular audio/midi interfaces with the latest UC drivers.
by ccenteno on Sat Sep 21, 2019 9:34 am
I can not use VSL software as a mixing control with my AB 44 with Windows 10. I can only install UC but I can not use VSL as in Windows 7. Is this correct?
