Been away for 3 years from recording, came back only to find my 1818VSL monitoring software is no longer supported.
Found out AFTER I installed the Universal Controller which wiped out the VSL Software.
Been looking ALL over for an archive for the VSL control Software. ANY Clues??
Thanks - RJ
by cristofe on Mon Mar 05, 2018 12:49 pm
It's on the 1818VSL downloads page. You just need to click on:
"Show / Hide all versions of software downloads"
One more thing.....before you attempt to install the legacy drivers make sure you do a COMPLETE and thorough uninstall of the new drivers.
https://support.presonus.com/hc/en-us/articles/210044723-How-do-I-uninstall-and-reinstall-my-AudioBox-drivers-in-Windows-7-or-Vista-
Cheers......Cristofe
by adzord on Fri Mar 09, 2018 8:59 pm
The Presonus website still has the 1.3 and 1.22 VSL drivers in the downloads section of the Audiobox 1818VSL page. I just recently put Mavericks and the 1.22 driver on my old Mac Pro so that I can use the VSL again. Makes recording enjoyable again compared to using cue mix in Studio One in my opinion.
MacBook Pro Retina, 13 inch Early 2015
2.7 ghz Intel Core i5
8 GB 1867 MHz DDR3
mac OS Sierra 10.12.6
Mac Pro late 2013
3.5 GHz 6-Core Intel Xeon E5
16GB 1866 MHz DDR3
Mojave
Presonus Quantum, Presonus Studio One Pro 4, Presonus Faderport, Presonus Digimax FS, Softube Console1MK II
by cristofe on Mon Mar 12, 2018 12:03 pm
You're correct. Just didn't realize you need to click on:
by dap9 on Sun Mar 18, 2018 7:50 pm
Hoping to avoid posting a new thread... I installed the Universal Remote and now I can't get my phones AND monitors to work at the same time.
So if I'm reading the above right, I need to uninstall the Universal Remote and reinstall the old VSL, correct? Thanks! What a pain!
by heinzhupfer on Tue Mar 20, 2018 6:16 am
HI:)
Is this virtual monitor software not available anymore?? I've bought this audiobox, but can't find Virtual StudioLive-Software.
How is this managed in Studio One?
Can I get this Software anywhere?
Thanks,
Heinz.
by cristofechabot on Tue Mar 20, 2018 11:28 am
:thumbdown:
Last edited by cristofechabot on Tue Mar 20, 2018 11:54 am, edited 1 time in total.
by cristofechabot on Tue Mar 20, 2018 11:40 am
:thumbdown:
Last edited by cristofechabot on Tue Mar 20, 2018 11:55 am, edited 1 time in total.
by cristofe on Tue Mar 20, 2018 11:45 am
dap9 wroteHoping to avoid posting a new thread... I installed the Universal Remote and now I can't get my phones AND monitors to work at the same time.
That is correct. You MUST uninstall the previous drivers as per the procedure outlined in the above link. PITA? Perhaps, but if you want your system to work properly......
by cristofe on Tue Mar 20, 2018 11:48 am
heinzhupfer wroteHI:)
Thanks,
Heinz.
Did you not read the above posts?? They very clearly state:
And:
So go to the 1818VSL downloads page:
https://www.presonus.com/products/AudioBox-1818VSL/downloads
And click on the "Show / Hide all versions of software downloads" link!
by heinzhupfer on Wed Mar 21, 2018 5:27 am
HI:)
@cristofe
I've read the posts before, but I've seen that this driver has only 8 MB, so not recognized that the software is involved with the driver....
So, another problem: (which is none)
Just for testing I installed first the newest 1818VSL driver 2.5.2. With this driver the buffer size goes down to 16, and with Sonar I have fantastic 0.4 ms latency.
In Studio One with this driver I have only ~5 ms and no Blue "Z", a green instead.
Now that I have installed driver 1.3 (64 buffers), in Sonar 1.4 ms latency, which is good enough and I have this fantastic Monitor Software VSL!
In Studio One now with the old driver I got the Blue "Z", so the older driver is better than the new one, possible?
Same Settings in Sonar and Studio One....
Is there any possibility to work with the BuiltIn FatChannel in 1818 and the Effects, but the newest driver 2.5.2 in Studio One for monitoring?
I've seen a video about that, but can't find it anymore....
Forgot: Win 10 64 (newest updates) all work fantastic with the audiobox.
Thanks,
Heinz.
by cristofe on Wed Mar 21, 2018 11:29 am
No. One or the other.
The Fat Channel is NOT "built in" to the 1818. It is part of the VSL software and runs on your pc.
If you want to use VSL and Fat Channel you must use the legacy 1.3 drivers. You cannot use 1.3 and 2.5.2 at the same time. You cannot even have both installed.
by heinzhupfer on Thu Mar 22, 2018 12:28 am
@cristofe
cristofe wroteThe Fat Channel is NOT "built in" to the 1818. It is part of the VSL software and runs on your pc.
But I'm quite sure that the Fatchannel and Effect processing is happening "in the box", so for that no CPU is used....
It would be possible to manage this in S1 directly as it does with "Studio 192" (switching Fatchannel processing from Studio 192 to Studio One (Recording/Playback)) for example but it is not implemented for the audiobox?
Thank you for answering:)
Heinz.
