I just bought a brand new USB96, trying to connect to a Dell XPS windows 11 laptop with only USB-C ports.
When I plug the 96 into an Anker USB-C 5-in-1 adapter, it is not recognized in any USB port. When I plug the 96 into the generic adapter that came from Dell, it does work, and is recognized by the Universal Controller. Why do you suppose that is? |
Some USB devices work fine plugged into external hubs but audio interfaces generally work best plugged directly into a USB port on a computer. Check the specs for your laptop and the external hub to see if the USB ports are USB 2.0 compatible because the AudioBox 96 has a USB 2.0 port.
https://www.presonus.com/products/AudioBox-USB-96/features
Download the STUDIO ONE 6 PDF MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Windows 11 Pro 64-bit (22H2), Studio One 6.1.0 Pro | Notion 6.8.2 | Universal Control v4.0.0.90879 Dell Inspiron 17 5770 (Intel Core i7-8550U 1.8 GHz, 4GB AMD Radeon 530 Graphics, 16GB RAM, Samsung 860 EVO 2TB SSD |
Trucky is right. Very often external hubs do not work well. It can be a connectivity or a power issue.
Your Audiobox may simply not be getting enough power from the Anker. I've always had much better luck with external hubs and docking stations that have their own power supplies.
