It might be that I overlooked something very obvious but I am a little bit stuck right now. I am using windows 10 with studio one and AudioBox USB. When recording or listening to playback the general volume level is extremely low, when I pull up the volume on studio one (input channel or master output, doesn’t matter) it starts to overdrive but doesn’t adjust the „base“ volume level. For windows system sounds, I can use the windows mixer and the output on the headphones is really loud when I turn it up, so something seems to work correctly. Note that the setup in general is working, ie I can record and play, but just the volume is way too low. Is there some kind of setting or knob or slider I need to use to adjust the headphones volume from studio one? Thanks in advance! |
What is the Mixer knob (Inputs/Playback) set to?
Download the STUDIO ONE 5 PDF MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Windows 10 Pro 64-bit (20H2), Studio One 5.1.2 Pro | Notion 6.8 | Universal Control v3.4.0.61835 Dell Inspiron 17 5770 (Intel Core i7-8550U 1.8 GHz, 4GB AMD Radeon 530 Graphics, 16GB RAM, Samsung 860 EVO 2TB SSD StudioLive Series III 32 v2.4.17466 |
Thank you for your quick reply!
The knob is set to "Playback". I just spent some time trying all the knobs and settings again, plugging all the cables in and out and at some point it started to work again, I am able to properly control the volume now from Studio One. I didn't really change anything so it might also be that there is just a loose contact or something else wrong with the hardware or one of my cables. I will update if it stops working again or I know what the issue was. Best |
Glad to hear it's working now!
