I am a new Presonus user. I can't believe I am alone in this issue. I bought the Presonus audiobox 96 bundle last week including the Studio Magic suite. I installed the Output Movement plugin and Studio One recognized it no problem. Then I installed the Phat Virtual Drummer plugin, but the Studio One browser doesn't see it. I have asked tech support for help, but I gather from the hundreds of unanswered queries in the knowledge base that I shouldn't hold my breath waiting for a response.
I'm using Windows 10. I have reinstalled Studio One and Phat several times. I've tried adding the location path in the options - location window, but it failed. I feel I've tried everything.
Any suggestions?
by cristofe on Mon May 13, 2019 11:38 am
As ALL of the plugins in the Studio Magic Suite are from different 3rd party developers, they may require that you register with their original developers. This can be further complicated as different developers use different registration and copy protection methods.
Phat is product of UJAM NOT Presonus. Have you been to their website? Posted of their forum?
Or contacted their customer support?
https://www.ujam.com/phat/
Furthermore Studio One Artist doesn't load just any VST plugins, these are special editions made to work with your DAW. If yow wish to run any and all VST plugins you must by the VST addon for Artist or upgrade to Pro.
by samshephard on Fri May 08, 2020 6:47 am
Hi. I have the same problem, with S1 Artist Bundle.
Read instructions, installed multiple times, abandoned after 2 hours.
In Cakewalk all Magic plug-ins run smoothly.
Many greetings
Sam
