Hi again guys, just having some trouble with my audio signal so I wanted to make a fresh new post about it.
Recently I've been having some audio skipping issues with my interface, and looking around I found that for some people reinstalling the driver fixed it. So I did... and now whenever I try to play audio with the two lowest buffer size rates (128 and 64), I get this distorted clipping sound. I works fine in 256 and above, but clips like crazy whenever I try to go below that buffer size. My Specs: Audio signal -Audiobox USB going through an USB 2.0 port. -Senheisser 202 HD PC specs: -CPU: i7 3770k -Motherboard: ASUS Sabertooth Z77 -8GB of RAM -SSD OCZ and a 2TB WD Black Caviar HDD. -GTX 970 -Display: 2 LG Monitors. One of them is also a TV. -----Windows 7 Ultimate x64------- PD: By the way, is using 64 buffer size forcing my CPU too much? From the Task Administrator of windows CPU Use never goes above 25%. I have no idea if that's a lot or not. Thank you! Nacho. |
You system seems capable on the surface, but something is surely going on. The distortion is most likely from CPU overload. If you watch the CPU meter in S1, you will probably see spikes in the cpu when you hear the distortion.
google for a program called "latencymon", and install. Its freeware so no cost. Hook up your interface as if to record, and run latencymon. Let it run for a while. It should give you an indicator of what is possible jamming up your signal. |
You might also want to open up Task Manager and have a looksee at what's running in the background.
Did you follow the above post regarding latencymon? Regardless of the power of a processor, and the amount of ram a computer has, there may be issues on a particular machine that need to be addressed. IRQ conflicts, background processes, and chipsets have a significant influence as well.
