I just found the audio input of Audiobox96 doesn't work with OBS. Once I record it, OBS shows the audio input signal. However, if you play it, it doesn't play the audio.
I googled it and found this article:
https://www.reddit.com/r/Twitch/comment ... _with_obs/
So, I followed the instruction of the first comment, but no luck.
https://youtu.be/WzV1UKEuAYA
Audiobox96 is set up perfectly. I've been composed my songs without any problem so far. So, I have no clue.
Studio One 6 Pro/ Lenovo Legion 5 laptop/ AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz/ Installed RAM: 40.0 GB (39.4 GB usable) / System type: Windows 10 Pro 22H2 64-bit / GPU: Nvidia RTX 3060 / C drive: SSD 512GB / D drive: SSD 2TB (int) / P drive: SSD 4TB (ext) / N drive: HDD 3TB 5400 rpm (ext) / Speakers: Presonus Eris 4.5 / Headphone: AudioTechnica ATH-M50x / Interface: Presonus Audiobox96 / Microphone: AKG P120 / Midi Keyboard: Korg MicroKey 37 / OontZ Angle 3 Bluetooth Portable Speaker
by Trucky on Wed Apr 26, 2023 7:38 am
The AudioBox USB 96 doesn't support "Loopback" recording that allows you to record the output of one audio application into another application. Other PreSonus audio interfaces (Revelator io24, Revelator io44, Studio 24c, etc.) do support loopback.
There's 3rd party products like Voicemeeter Banana for Windows that you can use to make this work with OBS. There's lots of YouTube videos available that walk you through this type of setup.
Here's the link for more information:
https://vb-audio.com/Voicemeeter/banana.htm
Download the STUDIO ONE 6 PDF MANUAL. Access your MY.PRESONUS account.
Windows 11 Pro 64-bit (22H2), Studio One Pro 6.1.2 | Notion 6.8.2 | Universal Control v4.0.0.90879
by Nothingness on Fri May 12, 2023 8:11 am
Trucky wroteThe AudioBox USB 96 doesn't support "Loopback" recording that allows you to record the output of one audio application into another application. Other PreSonus audio interfaces (Revelator io24, Revelator io44, Studio 24c, etc.) do support loopback.
Hi, Trucky.
I figured it out with Reastream. There were some wrong settings.
Thanks!
cron
