Bought my audiobox usb 96 a week ago or so.
Ive had driver issues since day one. Im on Windows 10
Im at my wits end here, using this is unbearable. It keeps disengaging, no audio. I have to try on change the sample rate in windows and other tricks to get it to trigger back on. Usually after I start rendering something in my DAW it will disengage again. No rhyme or reason.
Another issue which is bearable is, that audio will clip if keep it on full volume. Just music like on youtube and stuff like that, not in my DAW or anything. So I have to always keep the windows volume setting at 96 max. The external volume controls are not affected by this, so it seems like a driver issue.
I have the latest drivers. Why does there appear to identical Driver links for the USB 96 though?
https://ibb.co/HDYQ3Sg
Im using the first one. When I use the second one, it installs but when I open it, it just says "UNIVERSAL CONTROL" and no options or any view of my audio interface.
absolutely unusable device
by colek on Wed Apr 07, 2021 7:12 pm
Not sure it applies anymore, but i was told audiobox uses port enumeration. That means u haftoo plug it in the same port all the time. Not sure thats ur prob but it sure was mine. GOOD LUCK.
by cristofe on Sat Apr 10, 2021 12:07 pm
It could be any number of things. Have you optimized your pc for audio production? Have you disabled wi-fi? Are you plugged into a USB2 or USB3 port? Have attempted to do a PROPER uninstall/re-install of the drivers....or did you attempt install them several times on top of each other?
That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW, make and model of your audio interface etc....we often can't recommend a "simple fix"
Had you read the manual you would have known that the Audiobox is indeed port specific.
It must always be plugged into the port it was installed to.
